Answer: Sourcing a battery for Maestro in Canada - done!
After some research and a few tries .. I found a 12,000mAH battery that works and fits great in my Maestro and is available from Amazon Canada.
https://www.amazon.ca/dp/B00OZ7MYRQ/ref=cfb_at_prodpg
Power Bank, Lightning Power Bank®, Portable 12000mAh Dual USB External portable battery charger with LED display, Ultra Slim Aluminum body - sold by Amazon Canada, distributed by Lightning Power Bank. support@lightingPowerBank.com .. note I am not affiliated with the company at all -- I am just thrilled to have found something that works!!
Best,
Steve
VE7ORA
i have ordered
http://www.aliexpress.com/item/100-Original-Xiaomi-Power-Bank-20000mAh-Portable-Charger-Aluminium-Al...
will write a report as soon as I received the unit
73, de PE3DON
Thanks Steve Was going to ask someone at local harvest Saturday. Bill VA3QB0
I buy 2 battery from Mogix whit free shipping USA. I have open Account whit Shipito. Total amount 97$ Canadian for 2 very good product.1
Steve
Thanks for this update. This maybe our Canadian solution !!
and Don, I will be looking forward to your report.
Regards
Kevin, Va3KGS
I bought a couple of these, they were $23.99ea + free shipping. Works well in my Maestro.
http://www.amazon.ca/dp/B00XTXY0JW
Kevin VE7OVY0 -
Do you have to turn it on manually or does it turn on automaticity when you turn the Maestro on?
Jim
ka7gzr
The battery automatically senses the load when i turn on the Maestro, and the usb pack turns itself on. I've never had to turn the pack on manually.
It may not be as high mA/hr rating as some of the other ones mentioned here, but at 2.4A output, auto-on, lots of 5* reviews and since it was available in Canada, very cheap (nearly 1/2 the price of the other ones mentioned here) and no shipping hassles, it was my choice. So far so good.0 -
Very good. I like it because of the LCD display. There is a version available on the US Amazon I may try one.
Jim
ka7gzr
The one I bought/gave the link for don't have a display; which is likely why its a lot cheaper than the first one mentioned in this thread. If its tucked away inside the Maestro, you'll never see the display anyway! :-)
73, Kevin VE7OVY0 -
Thanks Kevin.
I see now the one you ordered.
I have the Polanfo Q5 Power Bank (among others). They have a LED display on the end of the battery. It shows % of battery remaining and is on when the Maestro draws current. I can see the display thru the slats of the back battery cover without removing the cover.
Jim
ka7gzr
Morning Don
Can you give us an update on your findings with this battery.
Tnx
Kevin, Va3KGS
- 370 Community Topics
- 628 The Flea Market
- 87 SmartSDR+
- 422 SmartSDR for Mac
- 270 SmartSDR for iOS
- 35 Aurora
- 244 FLEX-8000 Signature Series
- 937 Maestro
- 54 FlexControl
- 916 Genius Products
- 333 Tuner Genius XL
- 451 Remote Operation (SmartLink)
- 781 Peripherals & Station Integration
- 996 Third-Party Software
