USB Headset stopped working after upgrading to SmartSDR 1.8 - LAN Remote
Gary, KE8O
I run SmartSDR in LAN Remote all the time so I don't have to connect a MIC or Speakers directly to my 6300. I use a program called Audio Switcher to change my "default" sound device on the fly between the on-board sound card and my Jabra 9450 USB headset by clicking an ICON in the system tray. This combination has worked great since LAN Remote was introduced. Last week after upgrading to 1.8 things seemed to be fine at first until I switched from the on-board sound card to my USB headset. After switching to the USB headset I heard the RX audio for only a few seconds and then it stopped. I toggled back over to the on-board sound card and the RX audio returned. So back to the USB headset and it stopped again after a few seconds. This time before switching back to the on-board sound card went to You Tube and watched a video to see if other "windows" default audio could be heard through the USB headset and it worked fine. So windows is recognizing the USB headset as the "default" audio device but SmartSDR is not passing audio expect for a few short seconds after the initial switch. I downgraded to SmartSDR 1.7 and my USB headset is back in business. Anyone else experiencing anything like this after upgrading to SmartSDR 1.8 ?
...Gary, KE8O
...Gary, KE8O
I use the same Audio Switcher program for my USB headset while operating both LAN and WAN remote. Which is close to 100% of the time. I usually do not upgrade to new releases of anything until sometime has past and any issues are discovered by others. It was the same for 1.8. I did not upgrade so if this is an issue with the upgrade I would like to also know as I will not upgrade when they release it again after fixing the other known issues.0
Update: Today I reinstalled 1.8 and then did a cold boot of the radio before trying anything. The USB headset is working fine. I even powered off the radio and PC a couple of times to make sure it stayed working. I know that Tim is always telling folks to try a cold boot by dropping power to the radio for a few minutes if they experience a problem. Thinking back at the steps I had taken last week that was the only thing I didn't try. But then again I was working on my 13 Colonies clean sweep and needed to get back on the air.
...Gary, KE8O
- 654 The Flea Market
- 385 SmartSDR API
- 51 Aurora
- 968 Maestro
- 940 Genius Products
