Maestro Fast Boot
It would greatly make a cleaner start-up for me if there were to be a way to fast start the Maestro.
I only have one Flex radio so I would like to be able to bypass the "Select Radio" screen and then bypass the following "Select a Version" screen and go directly to where I was the last time I shut down.
It could perhaps be an option to boot holding, say F1 down, to see those two panels otherwise the Maestro boots the last Radio and Version.
I would be happy to lose the "Select a Version" screen altogether! I cannot foresee a tine where I would need to load an older version than the most current one.
David G4NRT
David G4NRT
3
Good points, maybe there is a way to convert a button to dual activity for this purpose. How long does it take to boot up going through the normal process?0
- 395 Community Topics
- 674 The Flea Market
- 187 SmartSDR+
- 192 SmartSDR for Maestro and M models
- 454 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 87 Aurora
- 325 FLEX-8000 Signature Series
- 984 Maestro
- 959 Genius Products
- 351 Tuner Genius XL
- 131 Antenna Genius
- 313 Shack Infrastructure
- 218 Networking
- 836 Peripherals & Station Integration
- 146 Amateur Radio Interests
