Koss SB40 and AD-1-Y Connector
N4TTN
N4TTN Member ✭✭
edited May 2019 in SmartSDR for Windows
I am trying to use my Koss SB40 headset with the AD-1-Y adapter cable on my Flex 6300 and it is not working. I tried turning on Bias in SmartSDR and I get no audio transmitting at all.
Did I get the wrong adapter?
  • Jay Nation
    Jay Nation Member ✭✭
    edited May 2019
    Oops!
    My first reply was about a different headset.
    Your SB-40 should have a dynamic element. don't enable the bias it's not needed.
    Make sure you don't have the plug inserted upside down. it's possible to plug it in both ways.
    I homebrewed an adapter for the SB-45 but it has an electret element and does need bias turned on.
    The pinout for the plug is in the Flex documentation look for the Hardware guide.
    73, Jay - NO5J
  • K9DUR
    K9DUR Member ✭✭
    edited January 2017
    This may be the same problem as with using the Heil adapter with a Yamaha CM-500. The Yamaha has a stereo mic plug, with the element wired to both the tip & ring. The Heil adapter has a mono mic jack. Therefore, when you plug the mic into the adapter, you short out the mic element. I found a stereo to mono adapter on EBay for about $2. Plug it between the mic & the Heil adapter, & all is well. 73, Ray, K9DUR
  • Jay Nation
    edited May 2019
    Ray's right. you can probably keep the AD-1-Y, and avoid homebrewing it.
    73, Jay - NO5J
  • K5CG
    K5CG Member ✭✭
    edited May 2019
    I homebrewed a jumper for both.
    SB40 pin 7 to sleeve, pin 8 to tip. Bias off.
    SB45 pin 7 to sleeve, pin 8 to tip and ring (shorted at the jack). Bias on.
    If I recall I didn't need the +20db gain on either headset.
  • N4TTN
    N4TTN Member ✭✭
    edited October 2016
    All is well in Headset land now. Thanks for the tip on the adapter Ray.
    I hated having the mic in my hand.
  • EA4GLI
    EA4GLI Member ✭✭✭
    edited November 2016
    Let us know how are the Koss SB40 doing with the Flex. I heard good things about that headset.
  • Jay Nation
    edited August 2016
    Danny
    Have you got both the SB-40 and the SB-45?
    Do you prefer one over the other? If so why?
    I've been using PC headsets for a couple years now. The SB-45 seems more comfortable than my last set. I can probably stand to wear them longer.
    I guess what I'm after is If you broke one set would you replace it with the same model, or begin to think about buying a spare of the other.
    73, Jay - NO5J
  • Lawrence Gray
    Lawrence Gray Member ✭✭
    edited July 2016
    You need to use a mono adapter on the microphone plug.  I use a Koss SB45, which does require bias with the Heil adapter and it works great.  Just use a mono adapter for the microphone.
  • K5CG
    K5CG Member ✭✭
    edited December 2016
    Hi Jay,
    I bought both because I wanted to compare the sound quality of the mics (dynamic vs electret). I settled on the SB-45 based solely on a fellow ham's feedback (Hey Dan! which one sounds more like me?). He was listening in the same room on an IC-718. A very scientific method you see. hihi
    They are so close in tonal quality I would have no reservations about using either. Comfort would be a much larger factor.
    73 Danny
  • Jay Nation
    edited August 2016
    Danny
    Thanks, to my ears a good electret mic competes quite well with high-end dynamic mics. The may cost less, but they don't sound cheap. I'll stick with my SB-45 until something cheaper and better sounding comes along.
    73, Jay - NO5J
