I have 2 problems with my Maestro
Mal
1 DEXP is grayed out.
2 Transmit in waterfall does not display properly.
#1 DEXP is not yet incorporated via maestro
#2 Have not heard anything wrt to this yet. Can it be enabled like in SSDR ?
Transmit in waterfall works fine in SSDR.
I am pretty sure it was working fine in the Maestro when I first set it up. Now I get a frozen waterfall or sometimes I get a black waterfall with a few colored lines.0 -
Yes sounds like more than just simply enabling tx in waterfall w/in maestro , if there is even such an on / off like that in maestro. Perhaps others have experienced the same.
Tap on <Display and adjust you BLACK and GAIN0
Problem 2
After fooling around with settings, I think that there is something being overloaded in the receiver.
If I set the receive ant to 2 with no antenna connected and transmit on ant 1 the waterfall works perfectly.
I don't think it is an RF problem, because with both receive and transmit set to ant 1 with an antenna connected the waterfall doesn't work even if I turn the power down to 0 or 1 watt.
If problem 2 persists, I recommend that you open a HelpDesk support ticket (http://helpdesk.flexradio.com) so we can investigate further.
- 115 SmartSDR+
- 922 Genius Products
- 124 Antenna Genius
