Newbie question FLEX6500 (How many antennas at the same time?)
Gastonet
Hi all, First of all sorry if this question is very **** or if it was answered before, but I didin't found something like this.
The question is quite simple. Let's suppose I'm using 2 slices (no matter if they are or aren't on the same band). Can I assign one antenna to each slice?
Thanks in advance.
Gaston (LU5AGQ)
Thanks in advance.
Gaston (LU5AGQ)
You cannot dedicate an antenna to one slice and a different antenna to another slice. There is only one receiver in the 6300 and 6500. You can set one antenna for TX and another for RX.1
TX yes RX no.
You have one SCU Spectral Capture Unit, so you can only connect one receive antenna to that SCU. You can however, have 4 panadapters or 4 VFOs on different bands on that same antenna.
Multiband antennas on a single coax like a hexbeam or a logperiodic are great antennas to use in this manner.
Other people use a multiband RX antenna, which you could connect to the RXA port, and then use a speccific TX antenna per band.1 -
Thanks to both. I thought the idea of having only one SCU will confine it to only one antenna, but as Salvador said, I remember someday transmiting on one antenna and receiving on RXA port, that's why my confusion.
Again, many thanks and 73.
Gaston LU5AGQ0 -
I'm glad you asked the question because I was about to ask a similar one.. Maybe one thread can elaborate on both of our inquiries.
Can anyone comment on the advantages and disadvantages of using "Ant2" vs "RXA" for a dedicated receive antenna?
I see in the manual it shows that RXA is basically a direct input to the receiver. Does that mean ANT2 has something in its path that would affect the input signal before it reaches the receiver?
I'm thinking that obviously ANT2 is being switched for TX/RX. Does that mean that while in TX mode, ANT2 is disconnected from the receiver and RXA is still connected to the receiver during TX?
I'm using RXA for my phased beverages via a phasing box connected to RXA. I seem to get more "transmit feedback" on the waterfall using RXA vs ANT2. But I don't use the ANT2 input because I don't want to accidentally TX on ANT2 and fry the phasing box.
Just curious what the ramifications are between the two inputs.. Thanks..
See page 40 ( antenna considerations) of the hardware reference manual for switching diagram.
AL, K0VM1 -
Gaston.
Name here is George and the call is N6VNI
I am using three antennas.M2 KT34XA 4 element beam, a rotatable dipole, and a G5RV. I am using a Diamond three position switch. You just have to be careful when changing bands, that you change the antenna if need.
Good question. I have had my 6500 now for about five weeks now, love it and learning. Have had my ticket now for 29 years.
PAST PRESIDENT OF THE SOUTHERN CALIFORNIA DX CLUB.
de
George Jacob N6VNI
Perfect! Thank you..
- 636 The Flea Market
- 144 SmartSDR+
- 261 SmartSDR CAT
- 199 DAX
- 45 Aurora
- 957 Maestro
- 57 FlexControl
- 931 Genius Products
- 302 Shack Infrastructure
- 141 Amateur Radio Interests
