1.8.3 upgrade problems
Simon Lewis
logged on tonight and found a new update mastro showed the update hit upgrade and it started downloading update started and maestro completed ok and then radio started upgrading too a long time ... like 15 mins eventually the maestro started to load the ssdr dash - only there was no pana freq displays. after a few mins Maestro stopped and reported an error and needs to be restarted it restarted itself and after some clicking and calibrating the radio finally showed the ssdr dash
second problem ...
no persistance any bands modes or configs
no persistance on maestro or pc
took a hard reset to factory defaults to restore this so 1.8 messed up the config.
third problem
wifi connection is now worse than ever ...
fourth problem
pana now seems less sensitive than before ... needs more testing but seems that beacons visible (just above the noise) are no longer visible
so far 1.8 has been very annoying!
second problem ...
third problem
fourth problem
Well at least your Maestro is working - there are a number us who currently have a bricked one ... engineering are working on it and we are hopeful of a swift fix!
David G4NRT
I didn't see those emails to that issue till after!
It took so long updating I was worried!
Hope you get a fix soon0 -
Sorry for me 1.8.3 R.I.P
There was a Beta test ?0 -
My update went flawlessly. It took about 15 minutes for the whole thing. I am in my RV with a slower than normal internet connection. I did PC first and updated radio then disconnected from Smart SDR leaving radio on. Them fired up Maestro and it went well1
Mine also updated with no issues. Both Maestro and 6500 ok.0
I have converted this topic to a support HelpDesk ticket (http://helpdesk.flexradio.com) for expedited issue resolution. If anyone else is experiencing an issue similar to this one, please submit a HelpDesk support ticket for issue resolution.
I went the same route with no issues.
I figure I'm going to have to update the computer anyway might as well update the 6300 from there. Maestro update went flawlessly.0 -
So, as of today, 7/2/16, I understand not to try and upgrade for the Maestro - just arrived and barely out of the box...but wait til new software is available?
tnx Bob K4RLC0 -
Bob
That is what we've been told.
Thanks, Steven, I forgot all about version mismatch issues in another thread. but I tried to fix that.
73, Jay - NO5J0 -
You should be able to roll back the version of SSDR to the previous version (1.7.xx) with your computer then use your Maestro.1
I usually wait a week or two to apply firmware updates on any device and check the forums for problems, but this time I just accepted the Maestro's offer of 1.8.3 as soon as I saw it, and the upgrade went smoothly. I removed the old version from the PC and installed 1.8.3 there too. Everything works. Radio is a 6500. In case it matters, the 6500 had just been powered on and I hadn't connected yet from either Maestro or PC.0
- 352 Community Topics
- 615 The Flea Market
- 8K Software
- 3 SmartSDR+
- 6.3K SmartSDR for Windows
- 412 SmartSDR for Mac
- 267 SmartSDR for iOS
- 250 SmartSDR CAT
- 187 DAX
- 375 SmartSDR API
- 9.2K Radios and Accessories
- 22 Aurora
- 211 FLEX-8000 Signature Series
- 922 Maestro
- 894 Genius Products
- 323 Tuner Genius XL
- 116 Antenna Genius
- 284 Shack Infrastructure
- 200 Networking
- 138 Contesting
- 974 Third-Party Software
