Slice alignment in Smart SDR
Tim VE6SH
Since upgrading to the Maestro and 1.7.3 of SSDR I have encountered an anomaly. I was demonstrating the Maestro to some local hams and then switched to SSDR. One of my profiles is for 10/15/20 which I used to be able to "stack" on top of each other (ie: three slices horizontally). Now the active is slice is on top and the two other slices below, but adjacent to each other. I can no longer stack the three slices horizontally not matter how I try and manipulate the width and height of the slice.
Adding a fourth slice also adds it adjacent to the bottom two slices.
I checked my display settings and they remain unchanged.
Any ideas?
Tim VE6SH.
Any ideas?
Tim VE6SH.
Try the little icon next to the X to close the slice, it will cycle through maximize and minimize.... that might have messed it up....0
Correct. You can have all three parallel, or have one "Major" and two "minors."
If you have 4 panadapters open, you can have all four parallel, or one "Major" and three "minors." Or you can have two "Majors" and two "minors." All by playing with the little boxes on the panadapter bars.
It is kind of slick this way.
Ken - NM9P0 -
Along the same lines , my multiple panadapters will display differently according to size of SSDR window displayed. If the vertical height of SSDR is shorter, opening a new panadapter will display it next to the already opened panadapter to the right of it. If I make the vertical of the SSDR window taller, newly opened panadapters will display below the already opened panadapter for the full horizontal length of the SSDR window. I suspect your overall size of displayed SSDR window has changed which causes the multiple panadapters to display differently vice 1.7.3 anomaly.
Thank you both! For whatever reason (Canada Day excitement perhaps), I overlooked that detail. Clicking the maximize button fixed it.
Tim VE6SH
sweet
- 337 Community Topics
- 607 The Flea Market
- 7.9K Software
- 6.3K SmartSDR for Windows
- 170 SmartSDR for Maestro and M models
- 401 SmartSDR for Mac
- 264 SmartSDR for iOS
- 247 SmartSDR CAT
- 185 DAX
- 371 SmartSDR API
- 9.1K Radios and Accessories
- 18 Aurora
- 188 FLEX-8000 Signature Series
- 913 Maestro
- 886 Genius Products
- 320 Tuner Genius XL
- 116 Antenna Genius
- 281 Shack Infrastructure
- 197 Networking
- 137 Contesting
- 741 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 954 Third-Party Software
