Maestro sofware version selection
Norm - W7CK
I've noticed that when I first turn on my Maestro, I see a list of the software versions installed. Is there a way to have the LATEST version automatically highlighted instead of always having to touch the screen and selecting it manually?
Is there a way to remove the older versions, at least from the display list?
Norm
Norm
The idea with retaining up to 5 older versions in Maestro is to be able to connect to different Flex radios that might have different software installed. I think this will make more sense when 2.0 comes out. I do like the option of defaulting to one if you want.
Any update on this? Is it possible to default to one version or remove old ones?0
Maestro will retain previous releases so you can revert back to an older release if desired. A user cannot delete them.
How many do you have showing? You should only have 3 right now.0
- 636 The Flea Market
- 143 SmartSDR+
- 261 SmartSDR CAT
- 199 DAX
- 45 Aurora
- 957 Maestro
- 57 FlexControl
- 931 Genius Products
- 302 Shack Infrastructure
- 141 Amateur Radio Interests
