near field probe
Thanks -- Keith KH6FQR
I set this thing up just to see how it worked and I got division by zero errors and a message saying that an outgoing call cannot be made since the application is dispatching an input-synchronous call.
Why not keep it simple and just connect a length of coax (RG58 for example) to the rec port and a few turns of wire at the other end. Seems it should work. 73, Jim
Hi James, Thanks, I'll try that. I was just checking to see if anyone had any experience doing this already. It seems like the Flex could be a useful tool for this sort of thing. It is certainly capable of "seeing" much more RFI than my other radios ;-)0
Keith, I agree that is an interesting idea..One of those "Why didn't I think of that" ....just be sure not to over drive it. Micro volts are fine. More is not. 73,, Jim
Sometimes the simplest solution is the most BRILLIANT
Just tried your suggestion myself with a 50 OHM resistor soldered across the end of a piece of coax.. worked ... was able to see RFI sources
Now to design a small coil with 50 ohm impedance @14.2MHz for even better sensitivity
To save you guys doing the math:
50 Ohm Coll @14.2MHz = 0.561 Micro Henries
Using a 2" diameter toilet roll...
4 turns x 2" diameter x 2" length = 0.552 Micro Henries
So all you need to do to make a HF Probe is to take an empty toilet paper roll, wind 4 turns over 2" length and you have close to 50 ohm probe...
Or use a small 1/4" Dowel (pencil)
36 turns x 1/4" x 4" = 0.492 microhenries
Howard, I love the use of a toilet paper roll... should be a standard for hams. I have wound many a project coil on them. Thanks for the info. 73, Jim
Ironic... The first ever crystal radio I built 65 years ago used a toilet paper roll for the tuning coil.
For you younger guys... we had toilet paper back then too....
Howard is younger than me. We had corn cobs and Sears and Sears & Roebuck catalogs.1
We actually used newspaper until we could afford real toilet paper....from which I stole the empty rolls for inductor forms...
A small one turn loop and 50ohm resistor in series on the end of the coax works well.
Andrew de vk5cv
That's what Sears catalogs were for.
On a technical side, why would the pickup coil need to be 50 Ohms when we are only trying to couple a few microvolts into the rcvr? we're not looking for maximum energy transfer by matching impedance. 73, Jim
Depends on the signal you are trying to see. The 6000 Series is an instrument capable of accurately displaying signals down to a range of -140dBm (20 nV) across a 50 ohm load. So if your trying to maximize the laboratory capability of the device you should use a 50 ohm load. On the other hand, if you are just trying to roughly see what RFI spurs are around then you don't need a resonant circuit. It took me less than 5 minutes to build a resonant probe so no big effort required BTW. Thanks to everyone for the idea.0
Yes thanks all for the information and interesting discussion! One other note -- use the Rx input rather than the Tx/Rx connector -- you don't want to accidentally send 100 watts out to your probe ;-)0
Just to be an absolute technonerd about this, I just spent the last hour playing with my vector network analyzer to tune the probe to exactly 50.0 ohms @14.200MHz.
I guess I have too much time on my hands this morning (more likely Jet Lag effects)...
Again... Thank you Keith for the idea and James for thinking of a simple probe solution.. I have already used the probe to find an RFI source that was bugging me and my other test instruments could not see...
Now I plan to play around designing a few different size probes...to see if I can get them into hard to reach places....
Now I know why I like this forum so much. Great ideas and shared information. Really stimulates my interest. What a super bunch of guys!!! Please share your designs with us.... I can see many uses for this. Jim
What??? You don't want a really high powered signal generator??? LOL Good point. Jim
I have a probe that I made just as Paul suggests, I left the centre conductor wire insulated so that when I was probing around in the radios I would not short things out!! Worked great for reading on the frequency counter. Also made a few probes on a piece of 3/4" PVC pipe with an SO239 connector for change ability.
Good Luck
Kevin, Va3KGS
Great paper. Very in-depth. Shows how a simple subject/idea can be so sophisticated. Jim
Yes, great paper, thanks for the link....0
- 376 Community Topics
- 106 SmartSDR+
- 427 SmartSDR for Mac
