Maestro VFO's are linked
Norm - W7CK
Every once in a while I somehow get both of the VFOs linked together. I have 2 panadapters open with one slice in each. Lets say A is on 20m and B is on 6m. Then every once in a while I somehow get the VFOs so that when I turn either VFO dial, both slices will change frequency. They both go up or down in frequency as I move just one of the dials.
I'm sure this is something I'm somehow selecting but for the life of me, I can't figure it out. I have to turn the Maestro off and then back on in order to clear up the problem.
Anyone else experiencing this? Any idea what I'm doing wrong?
It is actually a feature, which purpose I don't understand. Between the dials there is a button labeled A>B. if you do a long press on it it locks both VFOs together (A>>B) and another long press will give you back normal use of the VFOs without having to restart the Maestro.0
Salvador, maybe for 10m FM Relais?0
Fixed linked splits for contesting0
Thanks for the explanation, I will research those.... I can only see advantage for linked VFOs if you are working sats to compensate for doppler. Do we have this feature in SmartSDR?0
- 112 SmartSDR+
- 944 Maestro
