Waterfall location
James Madden
There are many you tube videos showing the waterfall and pan adapter stacked on the left side of the screen. I figured out how to raise and lower the bottom edge but how do i make the sides smaller and move it to the left?Jim
Drag and drop the Radio Panel to the left side of the screen.
Thanks but it doesnt work. I can select the top bar of the scrren and move the window, but when i felease the mouse nothing happens. Flex people?0
Pick up right next to the EQ tab. If you are getting just one of the panels to move you are picking up too low. Works every time.
That moves the contro,s on the right side bit i am still inable to move the waterfall or the panadapter.0
I see, I did not understand your question.
You use the display (panadapter) window sizing controls The "bar" and to maximize the window. That will result is the other panadapters to resize.0
Thanks Tim where is the bar you are referring to?0
Ps how do you create anothe panadapter and another waterfall? When i right click on the pan adapter or the waterfall creat another slicw shows ip whic appears in the one panadapter open but does not create a second pan adapter or waterfall. This is missing from the documentation. Jim0
It is on top right-hand corner of every Panadapter window. It is a small box with a bar at the top.0
This is documented in the SmartSDR for Windows Software User's Guide.
You click on the icon in the bottom left-hand corner of the screen that shows a spectrum with a "+" to add a panadapter. If you mouse over the controls, a tool tip will describe their function.0 -
thanks that helps me create a new waterfall but how do you make it smaller on the left side of the screen. as mentioned when i click on the to waterfall tool bar for waterfall or pan adapter and move it to the left and release the mouse it moves back to full screen to the right. there is no information in the documentation that i can find how to do this. i have searched on you tube and cant find anything also.
Jim0 -
test to get this comment to display0
ps, after creating a second waterfall it as all black there are no frequencies showing that exist in the second pan adapter.
jim0 -
clicking opn Live solves this problem0
Problem solved clicking th3 right square in the top of a panadapter moves it to the left. Didnt see that mentioned anywhere in the documentation.0
- 376 Community Topics
- 107 SmartSDR+
- 427 SmartSDR for Mac
- 942 Maestro
- 918 Genius Products
