Hard Case for Maestro
k3Tim
k3Tim Member ✭✭✭
edited June 2020 in Maestro
I hope I'm not stepping on FRS toes here... There was mention of a hard case for Maestro. This one seems a good choice:
http://www.pelican.com/us/en/product/watertight-protector-hard-cases/medium-case/air-case/1485/
Especially if a custom  fitting foam were available.
_..--
k3Tim
  • WX7Y
    WX7Y Member ✭✭✭✭
    edited June 2020
    Purchased this from MCM electronics who has China built clone of the Pelican case which aren't to bad, here in the attached Picture is mine.
    It holds the Maestro,  2 Batteries, MIC, Raspberry Pi Softether VPN box, AC and DC power supplies / Chargers, all needed cables, room for my Blue Parrot Blue tooth head set for when Blue tooth is supported, Verizon Wireless Jetpack, and the Mounting foot with **** driver.
    Need to order the folding feet when I get a few bucks ahead.
    You can also buy replacement Foam from MCM if you mess up or want to change something.
    73's
    Bret
    WX7Y
