CW Skimmer Freq. tracking
AH0U
I am using a 6700 and the latest Smart software and have CW Skimmer working but wnem I click on a signal, the radio does not track to the new freq but stays on the original signal... what am I missing??
You are missing SDR-Bridge (http://www.qrv.com/sdrbridge.html)1
No... I am using SDR Bridge0
Then I suspect something in SDR-Bridge isn't set up properly. I have skimmed 4 different bands at the same time and the frequency tracks properly regardless if I click on the skimmer waterfall or the SmartSDR spectrum display.0
I have had some issues with SDR-Bridge and CWskimmer tracking correctly. It rarely works the fist time I open it. I usually have to change bands and reopen Cwskiimmer a couple of times for it to work. The SDR-Bridge window always has the proper frequency but not CWskimmer. I believe I am running the newest version. Once I get it working, it works OK for the most part. However, I had a strange issue with it this past weekend. I couldn't get it to track on 6 meters under 50.8mhz. It would track fine until I hit 50.8 and then it would just stop. Never could get it to go below 50.8. The SDR-Bridge window would track the frequency properly but it wouldn't translate over to CWskimmer.
That is the same problem I have.... Except for Six meters....once I get it to run now it runs OK0
- 375 Community Topics
- 105 SmartSDR+
- 425 SmartSDR for Mac
