Pulsing noise on specific ant selection combination
Tom
I have strange pulsation that make work impossible. It is strange that I experience this problem only in specific combination of ant inputs.
Receiving and transmitting antenna should be different to eliminate the problem, for example ANT1 as receiving and ANT2 as transmitting....or vice versa.
RX A is not working with neither ANT1 nor ANT2 as transmitting antenna.
RX B is working with both ANT1 or ANT2 as transmitting antennas.
The same behaviour is persistent without actual antennas connected.
Please check video to understand the symptoms.
https://youtu.be/iuNI5MVLKkw
Many thanks in advance for the hint,
Tom, 9A6TKS
Tom, 9A6TKS
I have converted this topic to a support HelpDesk ticket (http://helpdesk.flexradio.com) for expedited issue resolution. If anyone else is experiencing an issue similar to this one, please submit a HelpDesk support ticket for issue resolution.
- 390 Community Topics
- 662 The Flea Market
- 440 SmartSDR for Mac
- 55 Aurora
- 971 Maestro
- 946 Genius Products
- 308 Shack Infrastructure
- 216 Networking
