Q) Voice keyer setup
Takeshi Yamada
Takeshi Yamada Member ✭✭
How do contesters organize the voice keyer and microphone?
I am considering to use voice keyer thru DAX TX1 and it works.   However, at the contest use I need to use ordinary microphone to respond to the call that is thru PC connection (NT1-A -> Steinburg U22 -> PC USB -> Flex6500 PC) requiring to put off DAX button that takes time and inefficient at the contest.
Am I misunderstanding the usage?
  • Bob K8RC
    Bob K8RC Member ✭✭✭
    edited November 2017
    There was a reply earlier in the weekend that stated that DAX was originally intended for digital modes only. Voice keyer use, as you have found, is not practical. This will supposedly be fixed in a future release.
  • Al K0VM
    Al K0VM Member ✭✭✭
    edited December 2016
    v 1.5.1 SSDR is not quit there yet.. insert PC sound card/N1MM+ DVK in path between the MIC and the radio line input.
    AL, K0VM
  • Ken - NM9P
    Ken - NM9P Member ✭✭✭
    edited June 2020
    I used N1MM+ voice keyer this weekend successfully.  I will try to post later this week with the details.  I have a lot of work to catch up after being out for a week.
  • Takeshi Yamada
    edited June 2016
    Any progress on this, Voice Keyer setup?
    Are you, voice keyer users, using analog audio from voice keyer to cable to MIC input?
  • AA0KM
    AA0KM Member ✭✭
    edited April 2017
    http://hotamateurprograms.com/index.htm
    Here is some software to look at.
    I have messed around with voice keyer seemed to work.
    I just started playing with some of these so not sure of reliability of the programs.
    73 Jeff
