Q) Voice keyer setup
Takeshi Yamada
How do contesters organize the voice keyer and microphone?
I am considering to use voice keyer thru DAX TX1 and it works. However, at the contest use I need to use ordinary microphone to respond to the call that is thru PC connection (NT1-A -> Steinburg U22 -> PC USB -> Flex6500 PC) requiring to put off DAX button that takes time and inefficient at the contest.
Am I misunderstanding the usage?
2
There was a reply earlier in the weekend that stated that DAX was originally intended for digital modes only. Voice keyer use, as you have found, is not practical. This will supposedly be fixed in a future release.
v 1.5.1 SSDR is not quit there yet.. insert PC sound card/N1MM+ DVK in path between the MIC and the radio line input.
AL, K0VM
I used N1MM+ voice keyer this weekend successfully. I will try to post later this week with the details. I have a lot of work to catch up after being out for a week.
Any progress on this, Voice Keyer setup?
Are you, voice keyer users, using analog audio from voice keyer to cable to MIC input?
http://hotamateurprograms.com/index.htm
Here is some software to look at.
I have messed around with voice keyer seemed to work.
I just started playing with some of these so not sure of reliability of the programs.
73 Jeff
- 633 The Flea Market
- 131 SmartSDR+
- 197 DAX
- 42 Aurora
- 955 Maestro
