DXLab SpotCollector and WinWarbler RTTY
N6WT Kent
Hi all
I made the switch to Windows 10 by doing a clean install on a new SSD. I got everything set up and working with DXLab and my 6500.
I am having a problem with clicking on a RTTY spot in SpotCollector, it QSY the radio to the correct mode and band but it is always off by 2k higher in frequency. If I click on a CW spot the frequency is correct. How do I fix this?
Kent
NC6B
Kent
NC6B
Hi Kent,
Have you set the 'optimal offset' (sweet spot?) to 2210? It is in the RTTY tab of Winwarbler configuration window.
Guy
Yes that is set to 2210. Here is a screen shot of that menu. Is there something I am missing?
Kent
NC6B
Something else I just noticed. When I click on a RTTY spot it is 2.13k higher than the correct frequency.
So if I click on a spot for 21.074,8 it tunes the radio to 21.076.930.0 -
Sorry Kent, but I am out of ideas. Sri I could not help.0
No worries.
I tried a post on the DXLab reflector and was told to check the same thing. I think this is a DXLab problem so I will follow up with them.
Kent
Step-by-step instructions for configuring DXLab's Commander and WinWarbler for operation with Flex 6000 are provided here. My understanding is that this issue has been resolved.
Thanks Dave!! All works now!
Kent
- 633 The Flea Market
- 131 SmartSDR+
- 197 DAX
- 42 Aurora
- 955 Maestro
