Unable to key or find Com/Ports with Version 1.7.30
I am a user of all the digital modes; specially JT65/9 etc. However, I cannot find where the Com/Ports are located? I looked for hidden ports as the administrator in Device Manager and there were none in sight. "No ghosted Com/Ports found."
I looked in the Flex Forum for answers and checked George's (YV5W) video. However, he was describing v.1.6 and a brief description of v.1.7. "A must see video" Excellent!
I have the icon for CAT v.1.7.30 which install/deleted several times, with no success.
Where or how can I have access to set the Com/Ports?
WJST-X v1.6.0 is receiving but I'm not able to transmit; no Com/Port to key.
Using Flex-6700 SmartSDR v1.7.30
Windows 10
Thank you in advance for any help you can provide
Your problem is Windows 10 Tim has a tutorial on the Flex website on the correct way to remove everything and reinstall it under W100
Thank you Howard ... Will get to work on Win10
I follow those instructions after I installed Win10.I spoke to Dudley about it.
The problem has been that I can't get rid of FlexVSP error. I deleted that error in the Control Panel, Programs and Features. And kept coming up. Then I was advised to use Revo Uninstaller Pro. I thought that was going to do it. Well, it's still present.; It comes up everytime I boot the computer. I search for the Fabulatech (? spelling) the Company that wrote the software; Regedit never founded either.0 -
Did you add com ports to Smart Cat ?
Clicking the Cat icon brings up the menu and at the lower left hand side is the add-button.
Win-10-Tim
Clicking the CAT icon does not open. Nothing comes up. That is the problem.
The CAT icon is in the taskbar. However, the only thing it opens when I click on it, it's a "FlexRadio Systems SmartCAT error."0 -
Do you have other virtual serial port software installed? My friend had both a 6500 and Anan. He had VSPM and SmartCAT installed and could not get SmartCAT working. I had to uninstall both and then manually cleaned all remnants of both from the registry before rebooting and reinstalling latest SmartSDR.
okay...
In the Settings -> System -> Apps
is FlexVSP installed?
If you **** the Smart Cat and start it again from a command prompt
C:Program FilesFlexRadio SystemsSmartSDR v1.7.30SmartSDR CAT> .Cat.exe
are there any errors?
I would try uninstalling the VSP driver and then re-install it using admin priv.
C:Program FilesFlexRadio SystemsSmartSDR v1.7.3064-bit DriversVSP
David,
I have no serial or virtual ports showing in Device Management. As a matter of fact, when I open DM, there is no remarks about Com/Port to open.
They were there when I was running Win7. However, after installing Win10 DM did away with being able to see the Com/Port. In other words they were gone/hidden or deleted; how? I don't know.
Tim,
I will work on your suggestion.
It looks like your suggestion may be the answer. I have not look for VSP drivers. I will keep trying and post later this afternoon the results.0 -
Tim, Howard and David,
I have twice deleted SmartSDR v1.7.30. Shut off the radio by disconnecting the DC source, reinstalled the software. and the error still there.
Tried the command prompt under administrator; copied and paste the command and typed them in case there was an error. Zilch no luck no how.
I used Revo uninstaller, checked the registry and there was no trace of FlexVSP error. I did notice that Revo had a CAT version 64 bit that was delete ...
I guess I will be in communication with Flex Desk to see what I can do, that I have not done already.
Thanks to all0 -
PROBLEM SOLVED!
Dudley at FRS remote control to my PC with TeamViewer solved the problem in less than 2 minutes!
When was it the last time your rice box company repaired your radio that quickly?
Tim's instructions on how to delete "FlexVSP Error" needs to be revised.
Thank you Flex.1
- 375 Community Topics
- 104 SmartSDR+
- 425 SmartSDR for Mac
- 999 Third-Party Software
