live interface button use?
Tony C kc2dis
On the latest version of SSDR 1.7.**** I see a small button on the right in between the pan-adapter and waterfall screen that says "LIVE" while hovering over it I get the text that says "Jump to live waterfall stream" What is the function / use of this? I can't seem to find documentation about it. Thanks.
If you 'pull' on the waterfall on the right, you can scroll back through 'history'. Whe you do that, the waterfall does not move, it is not 'live'. Clicking on the 'live' button makes it scroll again.
Tony I am pretty sure this has always been there. It is not new in 1.7.0
ok guys thanks for the quick replies. I guess I am not seeing that functionality... clicking this button does not seem to do anything. Ok about it being there in previous versions... thanks for the quick reply though...
Tony
oh ok I figured it out thanks I learned something new!
it's not real obvious at first
It looks like you should be able to click on it but of course you can't until you move the display time on the right.
Glad you found out how it works and makes sense one you see it work. hehe0
- 654 The Flea Market
- 385 SmartSDR API
- 51 Aurora
- 967 Maestro
- 940 Genius Products
