Forced 6700 DOWNLOAD?
DrJ
After I installed my new Maestro, I can no longer use my 6700. It requires me to download the PC's vertsion 1.7.30 to the previous pre-Maestro version (1.6) to function. Therefore, if I want to use my Maestro I have to wait for reinstall of 1.7.3 on the 6700, and if I just want to use my 6700 (no Maestro) it forces me to downgrade from the 1.7.3 to older version. ****? Help!
Have you installed 1.7.3 on your PC? If you run the old 1.6 version, it will require you to downgrade the radio firmware in order to be compatible with 1.6. This is not required, you only have to download and install the latest version.
If you have installed the latest version, then you are probably accidently running the wrong version!
Update your PC to 1.7.30 and connect via SSDR. Then shutdown SSDR boot your maestro and do the same update. Make sure you are using the right version when you start SSDR as it will add a new set of short cuts. Don't pick the wrong ones. Mike va3mw1
A good reason to backup profiles, and Uninstall the old stuff before installing new. Which is what FRS reccomends.0
Michael,
I did upgrade my PC to 1.7.30 then shut down ssdr then ran Maestro, (which is still buggy for me, such as no signals coming through on 40 m but great on 80m or vice versa, then it goes black for a few seconds then starts up again... very weird. I have a feeling this has something to do with software versions? But when I shut down Maestro and get ready to boot up my Pc and my 6700, it states my Pc is running the newest 1.7.30, but my the SSDR insists that "an update is required", but it forces me to downgrade to the 1.5.xx version that I was running pre Maestro receipt yesterday.
There is no need to uninstall first. Mike va3mw0
Did you uninstall the old version of SmartSDR? If not you will have two SSDR icons on your desktop. Maybe you are choosing the older version? Dave wo2x0
That was it! I didn't think it would continue to use the old version by default. I deleted the old version and now one problem fixed but an unstable frequency problem started. If I turn the "vfo knob" too fast the frequency displayed is unstable and shoes varying multiple of hertz. Eg 7.213.453 then 7.200.675 despite having the interval set to 1k.0
As you found out, you can have many versions of SSDR installed. No need to install previous versions, but you do need to make sure you start the right version.
The VFO problems could be many, but are you Wifi connected or hard wired connected? If Wifi, try to hardwire at least to do some testing.0
- 371 Community Topics
- 94 SmartSDR+
- 424 SmartSDR for Mac
- 270 SmartSDR for iOS
- 937 Maestro
- 54 FlexControl
- 996 Third-Party Software
