SSDR 6m tx envelope ( jt65/jt9 ) anomaly
km9r.mike
For 160 -10m, my tx envelope for wjst-x (jt65 or jt9) looks like the following. Nice clean purty.
I have recently been fooling around with wjst-x on 6m and made my first qsos on 6m kinda ( well at least I got a replies via psk reporter )
However, despite the positive result with 20w and an OCF dipole at 35ft, I noticed that the tx envelope on SSDR using wjst-x displays differently on 6m. There appears to be no negative consequence because of this , but I do not understand why this displays differently on 6m.
Do other users see the same ?
It is because you have the RX preamp turned on for 6m1
100% correct and this was not a test. Thanks for the help Tim. 6m preamp off and voila.0
And for the record, this is not a "bad" thing. The reason why is that the radio is receiving the actual transmitted signal and for display purposes, additional RF pre-amplification is not needed.0
Yes that is the way I took it. No worries here. Just a better understanding and something I should have been able to determine myself but this was throwing me for a loop until you turned the light switch on.0
You are supposed to use low power for JT....
I guess the 100w was for the test. 0 -
looks like about 20 watts to me???? I do have bad eyesight.. but not that bad .... at least I didn't think so!
LOL, you are right, I was looking at the RF Power slider
- 633 The Flea Market
- 131 SmartSDR+
- 197 DAX
- 42 Aurora
- 955 Maestro
