ODD behavior of FM on ver 1.7.30 of SmartSDR
EA4GLI
Member ✭✭✭
After installing SmartSDR v.1.7.30 I find some odd behaviour on FM mode.
- My audio is very high and distorted on FM when there is no signal.
- If I disabled SQL and change modes and go back to FM, SQL is enabled even though it is NOT enabled in the screen (SQL is NOT blue)
Have you cold booted the radio after the upgrade?0
Yes I have. Should I do a factory reset?0
Try that and see if it makes a difference. If not I'll enter it in as a defect.0
Factory reboot and still same issue.0
""If I disabled SQL and change modes and go back to FM, SQL is enabled even though it is NOT enabled in the screen (SQL is NOT blue)""""
A me TOO. I just click SQL on and off and it works. A switching issue for sure.
Not seeing FM wave form either .I see it on am/usb/lsb etc.0 -
10 meters needs attention too.0
I have entered this report into our bug tracker as defect #3592 for further investigation. Please report any additional information related to this specific issue in this community topic.0
The SQL issue happens in Version 1.6.21 as well.0
- 335 Community Topics
- 602 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 400 SmartSDR for Mac
- 263 SmartSDR for iOS
- 247 SmartSDR CAT
- 184 DAX
- 371 SmartSDR API
- 9.1K Radios and Accessories
- 17 Aurora
- 174 FLEX-8000 Signature Series
- 912 Maestro
- 52 FlexControl
- 881 Genius Products
- 318 Tuner Genius XL
- 116 Antenna Genius
- 279 Shack Infrastructure
- 196 Networking
- 137 Contesting
- 735 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 950 Third-Party Software
