Uncommandeed Maestro reboots
ka7gzr
Thus far I have had 3 non-initiated reboots of Maestro in the last two days. The error indicates the Maestro has faulted and it must reboot.
Jim
ka7gzr
I got a "Maestro has encountered a problem and must close" once on my second connection. Have not had one since and have shut down and restarted a few times during my 8 hour burn in.
Jim, as an Alpha tester we haven't seen many reports of this among us in recent times. My Maestro (6700) has been running continuously since 1.7.30 was released. Typically this may be related to an issue with your switch (if hardwire connected) or WiFi router is connected in that manner. May I suggest the following troubleshooting tips: 1. Temporarily connect the Maestro via ethernet cable (hard wire) to your switch. 2. Power cycle your router/WiFi 3. Test and if you have another failure then a. Backup your global profiles b. Reset your radio. The procedure is listed in the users manual or you can tell me your model number and I'll tell you how. c. Test the Maestro If these steps don't work then I recommend you open a help desk ticket with Flex. 73, Mack W4AX0
Thanks Mack. I have been running my Maestro mainly on Wi-Fi and occasionally on Ethernet. All these occurrences have been on Wi-Fi. and DIV mode. I will take your advice and go from there.
Thanks!
Jim
ka7gzr
- 246 Community Topics
- 489 The Flea Market
- 7.1K Software
- 331 SmartSDR for Mac
- 243 SmartSDR for iOS
- 223 SmartSDR CAT
- 163 DAX
- 348 SmartSDR API
- 8.6K Radios and Accessories
- 766 Maestro
- 41 FlexControl
- 733 Genius Products
- 255 Tuner Genius XL
- 85 Antenna Genius
- 229 Shack Infrastructure
- 153 Networking
- 120 Contesting
- 115 Amateur Radio Interests
- 813 Third-Party Software
