Only one RTTY M/S frequency marker visible when first loading a pre-saved global profile
Ray G6UJB
Ray G6UJB Member ✭✭
edited March 2018 in FLEX-6000 Signature Series
Is this a known software feature?
Just updated to 1.7.30, first thing that I noticed is that when I re-load an existing global profile that was saved with the RTTY mode set only one of the RTTY mark/space markers is displayed in the panadapter for the slice until I either click on the slice's frequency **** or I double click in the panadapter to re-tune the slice receiver.
  • Tim - W4TME
    edited March 2017
    This sounds a lot like a defect, so I have entered this problem report into our bug tracker (defect #3591) for additional investigation. Thank you for the defect report.
  • Rick Hadley - W0FG
    Rick Hadley - W0FG Member ✭✭
    edited January 2018
    Not seeing that problem here with my RTTY profiles, FWIW.
  • Ray G6UJB
    Ray G6UJB Member ✭✭
    edited March 2018
    Tim,
    Following up after Rick's message, I've done a little more investigation.
    This issue seems to be related to which slice, was last selected for tuning (i.e. markers are yellow) when the profile was saved.
    e.g.
    1 Pan - with 1 x RTTY slice is OK.
    1 x Pan - with 2 x RTTY slices - one of the slices will be OK the other missing a tone marker.  It seems the slice that was last selected for tuning when the profile was saved is the one the loads the RTTY tone markers correctly.
    2 x Pan - Pan:1 with 1 x RTTY slice and tuning selected, Pan:2 with 1 x RTTY slice - reload of profile slice results in Pan:1 tone markers OK, but slice in Pan:2 missing tone marker.
    Only seems to affect the RTTY markers.
    etc...
    Ray
    edited January 2018
    Ray, I was finally able to duplicate something like that.  My single band RTTY profiles open correctly and adding a second slice is also done correctly.  I created a dual-pan profile, with 4 correct slices, then switched back to each of my single band profiles, which remained correct, but when I opened the dual-pan/dual-band profile, 3 out of the 4 slices were only showing the mark trace until I switched those slices briefly to CW and then back to RTTY, whereupon both mark and spaces appeared correctly.
  • Tim - W4TME
    edited December 2016
    I added this info to the defect report.  Thanks
