Is this normal? Spikes on TX
K1ESE
Member ✭✭✭
Is this normal? Using my Flex 6500 and SmartSDR 1.6.1 and 4 watts output, the panadapter screen shows many spikes on the transmitted signal. Here's 17m.
13 watts on 20 Meters on a finer scale -
It's similar on all bands, worse on 20m better on 80m, but there on all.
73 de K1ESE
John
73 de K1ESE
John
Maybe RF in the Radioshack?0
Turn off the RF preamp. You should never need it on 20m. Once you do that, see what difference it makes to the spectrum display on transmit.0
Tim -
Here's with the preamp off -
73 de K1ESE
John0 -
Mine does this on 40. Now I have to find the preamp.
preamp on 40m?0
John - based on the pic with the preamp turned off, I have changed this post to a problem topic and converted it to a support HelpDesk ticket (http://helpdesk.flexradio.com) for expedited issue resolution. If anyone else is experiencing an issue similar to this one, please submit a HelpDesk support ticket for issue resolution.0
I have recently noticed the same issue on my 6500. I think it may have started when I turned on mic bias in order to use a new headset, but I'm not sure.
I will submit a Helpdesk ticket.
Larry, KC1DAD
Hi Tim
I think these are a non-issue:
https://community.flexradio.com/flexradio/topics/strange-tx-spikes-20m
k3Tim0 -
Not the same issue. The spectrum is different; it should not look like that on CW / TUNE.0
Sorry Tim - my mistake. Back to the bottom of the Elmer promotion list.
Anyway I tried to duplicate and with 10 watts into dummy load @ 14.010Mc see similar results. The grunge is 85 dB down though.
TiM0 -
This is what mine looks like.
Tim, I'll open a HelpDesk ticket with four different ham band pictures, both CW and SSB, in the 10 watt tune position. Same thing... 73, Dave Hamm K4EET
Edit: Since the server is still down, I'll post the pictures here so you can see them sooner...
Firmware Version 1.7.30.780 -
Tim -
Thank you. Dudley had me try a few things and now it's headed back to the mothership for repair.
73 de K1ESE
John0 -
Mine looks like yours now Tim. Trying to determine what changed other than clock
Back to the top of the Elmer Promotion list for me!
k3Tim
time.
- 375 Community Topics
- 104 SmartSDR+
- 425 SmartSDR for Mac
- 999 Third-Party Software
