ODD behavior of FM on ver 1.7.30 of SmartSDR
Member ✭✭✭
edited April 2017 in SmartSDR for Windows
After installing SmartSDR v.1.7.30 I find some odd behaviour on FM mode.
  • My audio is very high and distorted on FM when there is no signal.
  • If I disabled SQL and change modes and go back to FM, SQL is enabled even though it is NOT enabled in the screen (SQL is NOT blue)
Welcome!
  • Administrator, FlexRadio Employee admin
    edited March 2017
    Have you cold booted the radio after the upgrade?
  • Member ✭✭✭
    edited November 2016
    Yes I have. Should I do a factory reset?
    edited December 2016
    Try that and see if it makes a difference.  If not I'll enter it in as a defect.
  • Member ✭✭✭
    Factory reboot and still same issue.
  • Member ✭✭
    edited April 2017
    ""If I disabled SQL and change modes and go back to FM, SQL is enabled even though it is NOT enabled in the screen (SQL is NOT blue)""""
    A me TOO. I just click SQL on and off and it works. A switching issue for sure.
    Not seeing FM wave form either .I see it on am/usb/lsb etc.
  • Member ✭✭
    edited April 2017
    10 meters needs attention too.
    edited March 2017
    I have entered this report into our bug tracker as defect #3592 for further investigation.  Please report any additional information related to this specific issue in this community topic.
  • Member ✭✭✭
    The SQL issue happens in Version 1.6.21 as well.
