ODD behavior of FM on ver 1.7.30 of SmartSDR
EA4GLI
Member ✭✭✭
After installing SmartSDR v.1.7.30 I find some odd behaviour on FM mode.
- My audio is very high and distorted on FM when there is no signal.
- If I disabled SQL and change modes and go back to FM, SQL is enabled even though it is NOT enabled in the screen (SQL is NOT blue)
Have you cold booted the radio after the upgrade?0
Yes I have. Should I do a factory reset?0
Try that and see if it makes a difference. If not I'll enter it in as a defect.0
Factory reboot and still same issue.0
""If I disabled SQL and change modes and go back to FM, SQL is enabled even though it is NOT enabled in the screen (SQL is NOT blue)""""
A me TOO. I just click SQL on and off and it works. A switching issue for sure.
Not seeing FM wave form either .I see it on am/usb/lsb etc.0 -
10 meters needs attention too.0
I have entered this report into our bug tracker as defect #3592 for further investigation. Please report any additional information related to this specific issue in this community topic.0
The SQL issue happens in Version 1.6.21 as well.0
- 110 SmartSDR+
- 257 SmartSDR CAT
- 943 Maestro
