Only one RTTY M/S frequency marker visible when first loading a pre-saved global profile
Ray G6UJB
Is this a known software feature?
Just updated to 1.7.30, first thing that I noticed is that when I re-load an existing global profile that was saved with the RTTY mode set only one of the RTTY mark/space markers is displayed in the panadapter for the slice until I either click on the slice's frequency **** or I double click in the panadapter to re-tune the slice receiver.
This sounds a lot like a defect, so I have entered this problem report into our bug tracker (defect #3591) for additional investigation. Thank you for the defect report.0
Not seeing that problem here with my RTTY profiles, FWIW.0
Tim,
Following up after Rick's message, I've done a little more investigation.
This issue seems to be related to which slice, was last selected for tuning (i.e. markers are yellow) when the profile was saved.
e.g.
1 Pan - with 1 x RTTY slice is OK.
1 x Pan - with 2 x RTTY slices - one of the slices will be OK the other missing a tone marker. It seems the slice that was last selected for tuning when the profile was saved is the one the loads the RTTY tone markers correctly.
2 x Pan - Pan:1 with 1 x RTTY slice and tuning selected, Pan:2 with 1 x RTTY slice - reload of profile slice results in Pan:1 tone markers OK, but slice in Pan:2 missing tone marker.
Only seems to affect the RTTY markers.
etc...
Ray
Ray, I was finally able to duplicate something like that. My single band RTTY profiles open correctly and adding a second slice is also done correctly. I created a dual-pan profile, with 4 correct slices, then switched back to each of my single band profiles, which remained correct, but when I opened the dual-pan/dual-band profile, 3 out of the 4 slices were only showing the mark trace until I switched those slices briefly to CW and then back to RTTY, whereupon both mark and spaces appeared correctly.0
I added this info to the defect report. Thanks0
- 339 Community Topics
- 609 The Flea Market
- 7.9K Software
- 6.3K SmartSDR for Windows
- 172 SmartSDR for Maestro and M models
- 405 SmartSDR for Mac
- 265 SmartSDR for iOS
- 248 SmartSDR CAT
- 186 DAX
- 373 SmartSDR API
- 9.2K Radios and Accessories
- 19 Aurora
- 196 FLEX-8000 Signature Series
- 916 Maestro
- 888 Genius Products
- 321 Tuner Genius XL
- 116 Antenna Genius
- 283 Shack Infrastructure
- 199 Networking
- 137 Contesting
- 746 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 964 Third-Party Software
