Flex 5000a sdr installer update error. Please help
Andy Moffatt
Hi guys trying to setup flex 5000a. Installed the sdr v2.3.5 power sdr installer. Gone through the motions. At the end it says LOOKED FOR v2.0.15.10 and found v2.1.3.9 WOULD YOU LIKE TO UPDATE FIRMWARE NOW. Then the error external component has thrown an exception At powerSDR. Pal.readOp(opcode Ulnt32 data1, Ulnt32 data2, Ulnt32 & run At powerSDR. Console.loadFWCFirmware string version. At powerSDR. Console.InitRadio0 At powerSDR. Console.ctor string arts At powerSDR. Console.Main string arts . Please can someone guide through best installation. Many thanks Andy
Andy, the newest PowerSDR for the Flex5K is 2.7.2, not 2.3.5. What is your OS?
73, Alex - DH2ID
Andy you need to down load software for you Flex from this site
http://www.flexradio.com/amateur-products/flex-series/powersdr/
A fellow has been updating the software on his own Flex stop updated this soft ware when they came out with the 6000 series.
http://ke9ns.com/flexpage.html
And my web site has lots of info on your flex
http://www.w4wwj.org
73,jim W4WWJ
This error indicates a failure for the PowerSDR software to properly communicate with the radio hardware via the Firewire connection.
I have changed this post to a problem topic and converted this topic to a support HelpDesk ticket (http://helpdesk.flexradio.com) for expedited issue resolution. If anyone else is experiencing an issue similar to this one, please submit a HelpDesk support ticket for issue resolution.
I have also seen the first error screen capture 2 days ago when I reinstalled PowerSDR for my FLEX5000, I hit OK and everything finished installing and run fine with the radio so this is not a isolated error but may be a hardware error.
I have ran the FLEX5000 since 2008 on several different computers so I guess I may need to change the Ethernet card and / or cable out and hope it's not the Radio.
This was after a full Reset and reinstall of the software.
Running WIN7 64K
73's
Bret
WX7Y0
- 107 SmartSDR+
- 427 SmartSDR for Mac
- 942 Maestro
