6500, Exp 2K-FA, how to upgrade to 1.6.21
At the moment I have my 6500 running as follows:
SW: V1.5
Ddutil: V2
2K-FA connected via Ddutil passive listener port on a real RS232 port
2K-FA also connected via USB to the little Expert-App
This config running smooth and stable already a year now. For me it is a big advantage to have the amp controlled by Ddutil (frequency and Autodrive) as well as the possibility of switching the amp on/off + seeing the display through the SPE-app.
Now I want to upgrade my reliable and stable system to 1.6.21, mostly because I don’t want to miss the Maestro train.
As far as I understand for now I don’t need Ddutil anymore for my config because of the ability to create comports (even hardware) in the redesigned CAT.
What features will I miss going this direction except Autodrive?
Any input from users with the same config is very welcome.
Regards, Jo
dj3cq
I still use DDUTIL with my 2K-FA0
Lawrence, Did you the 2K-FA-FW-Update to use Ddutil V3?
73, Jo
Jo, i did, all works fine, however keep DDUTIL for power drive control and some macro1
thank you Sergey, saw your pics in the other Expert thread, just wanted to be sure...
dsw, Jo
Absolutely Jo, only one threat can be here - power interruption during FW upgrade , you know0
"Now I want to upgrade my reliable and stable system to 1.6.21, mostly because I don’t want to miss the Maestro train. "
Hi Jo, II would wait until Ver 1.7 is released which gives you the Maestro interoperability I think you are looking for.
My came with the current firmware. Good luck0
- 379 Community Topics
- 634 The Flea Market
- 135 SmartSDR+
- 199 DAX
- 43 Aurora
- 956 Maestro
- 301 Shack Infrastructure
