I have an Ameritron al-811 amplifier that I'd like to hook up to my 6300.
PB Shell - k7shl
I have an Ameritron al-811 amplifier that I'd like to hook up to my 6300. If I use a rig buffer like an ARB-704, do I need a special plug and play cable? Do I need a rig buffer? Etc. Thanks.
No special cables needed. The ARB-704 is not required, but a keying buffer is recommended as a best practice to protect the 6000 keying interface from voltage transients that may damage it.2
I have ameritron 811.....I used to use a Heil FS-2 Foot switch.....and it worked good....thats alll you need...however I thought my Flex needs something more advanced ....and I got an Elecraft KPA500.....Now its seems I have a Flex 6300 with 500 watts
George
YV5WZ0 -
If you like the Rube Goldberg (if you remember that, I know how old you are) approach, I used a Radio Shack 5vdc relay and borrowed 5vdc from the accessory connector on the back of the Flex. I keyed the relay with the TX1 contacts and key my amplifier with the SPST contacts of the relay.
I use an ARB-704 and it works fine
George,
What kind of cable did you use with the Heil FS-2? Do I need a microphone cable assembly (like the CC-1Y) or ??
Thanks.
-Phil, K7SHL0 -
I don't Recall at this moment...but I will check tonight and letting you to know0
Remember to use TX delay when using an amp with a slow relay like an 811.0
Hello, Trying to interface my 6400 to and old Ameritron 811... can you recommend an alternate keying buffer?
You can't use the Ameritron one?1
- 376 Community Topics
- 107 SmartSDR+
- 427 SmartSDR for Mac
- 918 Genius Products
- 295 Shack Infrastructure
- 207 Networking
