Does anyone know what could be causing my water fall not to work? all other adapter displays work
This using psst on 1500
Welcome!
  • Member ✭✭
    edited June 2018
    not much info Dale. Are you in the panafall or waterfall mode. Centre bottom of the screen is a drop down box to select it.
  • Administrator, FlexRadio Employee admin
    edited March 2017
    Try doing a factory reset of the PowerSDR database and see if that improves WF display.
  • Member
    edited April 2016
    I, too, suddenly have lost Waterfall display on 'Panafall' and 'Waterfall' display. All other functions seem normal, even in 'Waterfall' display with no tune information showing, (the frequency numbers scroll normally).  Tim: If by 'doing a factory reset of the PowerSDR database' you mean execute the 'Factory Defaults' button on the 'PowerSDR Setup' screen, I tried that, No Joy. PowerSDR v2.7.2 windows 10 has worked from first startup several months ago.
  • Member
    edited April 2016
    My 3000 has the same issue. 2.7.2 and Win 10. Everything else works perfectly normal?
    edited March 2017
    Yes, the factory reset is the reset to Factory defaults.  If that did not work. try updating your video driver  using the latest version from your video card manufacturer rather than using the driver Microsoft included with Win10.
  • Member
    edited March 2017
    Updated Video Driver.  That worked, Thank You.
    edited December 2016
    Eureka! Thanks for the update.
