Does anyone know what could be causing my water fall not to work? all other adapter displays work
Dale Neace
This using psst on 1500
not much info Dale. Are you in the panafall or waterfall mode. Centre bottom of the screen is a drop down box to select it.
Try doing a factory reset of the PowerSDR database and see if that improves WF display.0
I, too, suddenly have lost Waterfall display on 'Panafall' and 'Waterfall' display. All other functions seem normal, even in 'Waterfall' display with no tune information showing, (the frequency numbers scroll normally). Tim: If by 'doing a factory reset of the PowerSDR database' you mean execute the 'Factory Defaults' button on the 'PowerSDR Setup' screen, I tried that, No Joy. PowerSDR v2.7.2 windows 10 has worked from first startup several months ago.
My 3000 has the same issue. 2.7.2 and Win 10. Everything else works perfectly normal?0
Yes, the factory reset is the reset to Factory defaults. If that did not work. try updating your video driver using the latest version from your video card manufacturer rather than using the driver Microsoft included with Win10.0
Updated Video Driver. That worked, Thank You.
Eureka! Thanks for the update.0
- 383 Community Topics
- 638 The Flea Market
- 145 SmartSDR+
- 434 SmartSDR for Mac
- 273 SmartSDR for iOS
- 261 SmartSDR CAT
- 200 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 304 Shack Infrastructure
- 142 Amateur Radio Interests
