What Souncard or Rig Interface you use?
Cheers...Happy Sunday!
George,
YV5WZ
George, You do not use a hardware interface. SmartSDR comes with a program called DAX (Digital Audio eXChange) which emulates several "soundcards" in software. You select one of the DAX channels in your digital mode software. 73, Ray, K9DUR0
Thank you Ray......!! I appreciate your time and care of answering me.....
I was wondering if I add a new soundcard (best than I actually have) my signal would be better.
RF gonna drives me crazy...
73, George
No, using a soundcard of any type only degrades your signal. To use a hardware interface & soundcard, the digital signal has to be converted to analog, passed through the interface, & converted back to digital. The D/A & A/D conversions add a small amount of distortion by their very nature. Using DAX, everything is kept in the digital realm & therefore no distortion due to the conversions. -- 73, Ray, K9DUR1
Thank you Ray......I appreciate it0
Thank you Ralfh (KF4HR)!
I appreciate your care about my business....Great video...Cristal!0 -
One of the best things you can do to reduce RFI in the shack is to go to a wireless keyboard and mouse. The wires act like little antennas and pick up RF just where you don't want it. I use Logitech but there are others.
73, Bill W6WRT
George, I had issues with RF and hum until I added ground wires to my ground bus for my computers. Each piece of equipment has a short, heavy, # 8 stranded wire to a copper bar which then goes to my ground electrode just outside my shack. This is in addition to the 3 wire cords which provide a safety ground. It did work for me. 73, Jim
Thanks Bill I have Mouse and Keyboard logitech too0
I suggest you read my paper on How to Build a Quiet Station...
Here’s a link to PowerPoint “How to Build a Quiet Station V2.pptx” in my Dropbox for a talk I gave at the San Diego DX ca club in July 2014.
https://www.dropbox.com/s/d2yturid60n...
Here’s a link to PDF “How to Build a Quiet Station V2.PDF” in my Dropbox:
https://www.dropbox.com/s/kffp92esffo...Remember you can never had too many Ferrites on your station.
DEFINITELY DO NOT USE a SOUND CARD or EXTERNAL RIG INTERFACEThey only make things WORSE.
If there is a problem that an undue number of ferrites is not curing, though, you need to root out the source.0
James, I couldn't have said it better ;-)
If HF is not where it belongs, string heavy ground wires!
All my equipment is grounded and I use different power supplies for the TRX
and my inferfaces and TNC's, when operating PACTOR or using my TS2000.
I have never had problems with HF and my equipment, although I regularly
blasted external equipment, like mice and lamps, until I used a lot of ferrite beads on them :-)
73, Alex - DH2ID
AIUI, the OP is asking if fitting a better sound card will produce a better signal on tx or improve the rx analogue signal sent to the decoding program than the integrated one.
Could be wrong, would not be the first time <blush>.
Alex, I think it comes from my 42 years in medical x-ray, building and fixing cardiac cath labs. We needed to keep equipment current leakage down in and around the patient for 1.5 meters. We could get it down to about 5 or 6 microamps if you were very careful. I have never needed ferrite beads in any of my stations and I have run some serious power ( currently run 1200 watts). Also, a truly balanced antenna system really helps. 73, Jim
EXACTLY correct, George. Get to the cause of the problem. High common mode current on coax may be a problem for him. 73, Jim
QED
Thanks James....I'm working on it0
Thanks Howard.....I have your paper just at side of my Bible.....I read it...and I will read again.....more ferrites are coming0
That was the hidden part of my question.....Thanks Guy
I have read some sound card may decode -26 even -29....and others barely reaches -140 -
To Quote Ray:
"using a soundcard of any type only degrades your signal. To use a hardware interface & soundcard, the digital signal has to be converted to analog, passed through the interface, & converted back to digital. The D/A & A/D conversions add a small amount of distortion by their very nature. Using DAX, everything is kept in the digital realm & therefore no distortion due to the conversions."
So you are already doing your best with DAX and your 6000 Series.. a Sound Card will only make it worse
FYI - I have consistently seen decodes of -29 with my 6700.
A couple of years ago Rob WA3IHV and I ran some tests of a Signal Link and a IC-7700 vs a 6700... the 6700 and DAX consistently would decode at least -6dB better than the Signal Link.. we did not test the Signal Link on the 6700 because of the obvious degradation of the Digital to Analog to Digital process
Roger That!....(Thumb up)0
- 655 The Flea Market
- 438 SmartSDR for Mac
- 385 SmartSDR API
- 52 Aurora
- 969 Maestro
- 940 Genius Products
