Instal Errors Flex 1500 & PowerSDR
I have a FLEX-1500. I've noticed that the turn-on sequence is important. With the USB connected between the FLEX-1500 and your computer, turn on the FLEX-1500. (12V power must be connected to the FLEX-1500 of course.) Wait a few seconds. Then, click on the PowerSDR icon.
The PowerSDR software has to know that there is a radio connected before it can proceed.
If you do as I have indicated and it still says "No Devices Found" then there is a driver problem, or the radio has failed. Try re-installing the driver.
- Steve W4OGM
How do I instal the driver?0
The PowerSDR v2.7.2 Integrated Installer available at http://www.flexradio.com/amateur-products/flex-series/flex-1500/ under the Downloads tab should install the driver. I suggest you download it and try that.
- Steve W4OGM
I have converted this topic to a support HelpDesk ticket (http://helpdesk.flexradio.com) for expedited issue resolution. If anyone else is experiencing an issue similar to this one, please submit a HelpDesk support ticket for issue resolution.
- 379 Community Topics
- 631 The Flea Market
- 123 SmartSDR+
- 193 DAX
- 39 Aurora
- 950 Maestro
- 925 Genius Products
- 337 Tuner Genius XL
