Maestro Tilt Hing Feet Accessory
2»
  • Member, Super Elmer Moderator
    edited May 2016
    I use a Belkin WeMo Maker wired up to the remote port on the 6700. I can toggle the radio on & off from either a PC, Android device, or iPhone.
    I use a second WeMo Maker to turn the Acom 2000a on remotely.
    A Denkovi Internet relay board allows me to toggle the power supply and other devices on & off
  • Member ✭✭✭
    edited March 2017
    Like your title - sounds exotic adding "Tilt Hing Feet" [sic] to a Maestro.  Out of context it could almost be the opening sentences from a novel!
    More seriously thanks to the whole FRS for the continued advance information!
    And of course Happy Birthday to Gerald on Monday!
    Steve K9ZW (who intends to make his Maestros exotic Maestros with "Tilt Hing Feet" on each!
  • Member ✭✭
    edited December 2016
    Tim,  The QUALITY on the TILT feet must be EXCELLENT !!!!
    I have been watching the Video for 3 days now and they haven't
    skipped a beat yet ....   I gave up counting the number of TILTS.
    Ken  W9IE
  • Member ✭✭
    edited June 2017
    Will there also be a 20% discount on all accessories like this for we original Maestro buyers when purchased at the time of payment for Maestro?
  • Member ✭✭✭
    edited November 2016
    I order my Maestro with the optional feet.
    I was wondering if they slide underneath the Flex radio.
    The gap is 15mm or about 1/2 inch.
  • Member ✭✭✭
    edited July 2017
    Another request... would it be possible to get pictures of the Maestro on top of a Flex 6300 and a 6500/6700 and another one in front of the radios? I am trying to think on the better placement for it in the radioshack and I don't seem to find pictures online with the Maestro in those configurations.
  • Member ✭✭✭
    I would love to see someone produce a simple box with AC plug-in on one end, a relay inside, and two RCA connectors on the other end - one for N.O. and the other for N.C contacts of the AC relay.  It could probably be as small as an iPad charger.  I would probably pay a few bucks for a couple of those!  I bought two cheap AC relays from Amazon with the intention of building my own unit.  They came from China and were only a few Dollars apiece.  Six weeks later they arrived, poorly packaged, and one of them was broken.  I don't want to mess with returning something to China for a few bucks.
    I still need to round up a fuse block, and case......I already have a WiFi powered AC Switch that only cost about $22.
    Ken - NM9P
  • Member ✭✭
    edited February 2017
    Will the Maestro with the Tilt Feet accessory fit into the soft and hard accessories cases?  Or will the feet need to be removed first?
  • Member
    It will fit with the feet on....
    Lou N2TU
  • Member ✭✭
    edited May 2016
    been thinking about that too Salvador
    I think I will buy the rack ears and rack mine
    The Maestro seems to be as wide as a 6000 case if not slightly wider
    And with the tilt angle I think I will have this on the bench in front of me
    I don't need to see the radio and I can free the space and run the LAN cable into my shack network
    I have 2 x 6500's and if Maestro is as good as I think then I will add a second into the VHF-SHF station
    Have a look at some of the vides on youtube from hamfests - there is a pic of a maestro on a 6300 ... its (Maestro) way bigger than I thought!!
  • Member ✭✭
    edited August 2016
    Gerald I bet if you see someone high up at Flex they could give you a discount
  • Member
    Here you go.  Plug it into your Wifi AC Switch and your set to go.
    http://www.digital-loggers.com/ac.html
    John
  • Member ✭✭✭
    Perfect! Thanks a bunch. I wish I had seen this a few months ago.
  • Member ✭✭✭
    I clicked their link that said "pay via Amazon" and found that the price was $8.95. Not bad, but they wanted $9.95 to ship it! So I closed that page and went directly to Amazon. Still was 8.95, but with Amazon Prime I get free two-day shipping! Nice.....
