Device Description Incorrect
When I run the FlexRadio program my Device Description shows my radio as a FlexRadio Systems FLEX-3000.
When I try to run PowerSDR it tells me I need a firmware upgrade. When I answer yes to that upgrade the firmware update window appears but just hangs.
I am assuming the firmware in this box is really really out of date so I tried following the instruction for a manual install through the Flex Radio app. When I locate and try to install the latest 5000 firmware I receive messages stating this is not allowed because my product IDs don't match.
I don't want to proceed any further without some instruction since I am afraid I might brick the radio. Any help is appreciated.
73 de Bob (KI6DY)
IIRC, the firmware requires being "sequentially" updated.
That is, if what's installed in the radio is too far out of sync with the version of PSDR you're trying to use, it won't load the newer version.
I hope somebody corrects me if I'm wrong, or posts of a utility to get around this.
Sorry I can't be of more help!
73, Jim0 -
I have changed this post to a problem topic and converted this topic to a support HelpDesk ticket (http://helpdesk.flexradio.com) for expedited issue resolution. If anyone else is experiencing an issue similar to this one, please submit a HelpDesk support ticket for issue resolution.
This was all fixed by Dudley over the phone and with Teamviewer. What great customer service, I'm very impressed. I have alot to learn but have already made several contacts. Thanks Tim and Dudley Bob (KI6DY)0
Just out of interest, what was the problem?
The problem was, as I expected, a very old and out of date firmware version in the radio, something from 2008 or so when the radio was purchased.
I not sure I followed everything that Dudley did but I believe this was the fix:
1. Roll back the firewire driver to some earlier version.
2. Flash the latest firmware into the radio.
3. Install the latest firewire driver.
He then went into the Flexradio App and SDR and made sure everything looked good and was set correctly.
Then he proceeded to give me half hour tutorial on PowerSDR.
As an aside, I am an exclusively digital operator, JT65, JT9, and RTTY mostly. However, after hearing the SSB audio that came out of this rig, I am seriously considering hooking up a microphone if I can find one in a drawer somewhere.
Bob (KI6DY)
Hi Bob. Thanks for getting back to us. Hope to snag you for the log. I still need to get a fellow flexer from this forum in the log, sadly.
- 356 Community Topics
- 619 The Flea Market
- 8K Software
- 19 SmartSDR+
- 6.3K SmartSDR for Windows
- 414 SmartSDR for Mac
- 267 SmartSDR for iOS
- 252 SmartSDR CAT
- 188 DAX
- 377 SmartSDR API
- 9.2K Radios and Accessories
- 26 Aurora
- 221 FLEX-8000 Signature Series
- 927 Maestro
- 900 Genius Products
- 458 Power Genius XL Amplifier
- 325 Tuner Genius XL
- 117 Antenna Genius
- 287 Shack Infrastructure
- 202 Networking
- 141 Contesting
- 980 Third-Party Software
