RMS Express and SmartSDR CAT
adrian miura
Tried using the "Configuring WinLink RMS Express with the FLEX-6000 and SmartSDR" but could not get the radio to keyup without using VOX.
I have no problem using FLDIGI without the VOX button selected.
In SmartSDR is have a CAT port assigned COM5 with auto switch TX selected
the quick instructions - You need to . ..
Click ADD
Go to top of selection - Port Protocol, click drop-box and select PTT
From there, you can tell it what comm port, what 'PIN' to use and how you want the polarity.
Good Luck !
Thanks Walt, That worked.
as the PIN and polarity I just took the default settings.
Does it matter on the 6000's?
Adrian0 -
No matter for the 6000 since this is all software and no 'real' pins are involved (I am guessing about the 6000 internals).
I think you just need to make sure all programs are configured the same, which it appears you have.
Glad I could help . .
- 378 Community Topics
- 117 SmartSDR+
- 37 Aurora
- 946 Maestro
- 923 Genius Products
