flex-6500 documentation ???
Cal Page
I am considering a 6500 but would like to look at the documentation. Can you make it available? Specifically, I'm guessing but it connects to a pc with firewire because you sell those. What types of connectors are available for me to hook up cw skimmer or Signal Link modem? AB1XT
All documentation is found at http://www.flexradio.com/support/downloads/ The 6000 series uses standard Ethernet not FireWire v1
and... it does not use Firewire. CW Skimmer is easy to set up using SmartSDR and SDRbridge. You can sell your SignaLink because with a Flex radio you don't need it. A Signalink is used to get audio in/out from computer to radio and the Signalink uses VOX to execute a PTT of the radio when needed. With a Flex you do all this with the Flex DAX system and by configuring your software (Flidigi, Mixw, Winwarbler, DM780,WSJT, Multipsk, etc ) to interface with the Flex.
Andy K3UK0 -
As Howard said, the connection to the radio is via Ethernet, not firewire.
No connectors are needed for CW Skimmer or the SignaLink. Both CW Skimmer and your soundcard digital program connect directly through software. SmartSDR (the radio software) includes a program called DAX which emulates a soundcard. You will not need your SignaLink at all.
73, Ray, K9DUR
Since everything digital is internal to. The computer you tend to get much better digital performance as signalink introduces analog to digital to analog conversion distortion that you do nort get with a pure digital system. Nor do you need external cables which can pick up or generate RFI0
- 378 Community Topics
- 116 SmartSDR+
- 37 Aurora
- 923 Genius Products
