PSK DXlab WW config flex 6300 Current software
Mike Christmas
edited December 2018 in SmartSDR for Windows
I am running DX labs using WW has anyone been able to configure it that can help I am not at all interested in using HRD but am willing to try any other PSK software.
All postings I have looked at on here is using the old DAX and now that it is included in the software it looks different and the old configs no longer work.
I can not get the radio to Key and yes I am in DIGU with DAX turned on 1
I work best with screen shots HIHI
Any help would be great.
  • DrTeeth
    DrTeeth Member ✭✭
    I think this is what you need, http://www.dxlabsuite.com/dxlabwiki/FlexSignature. Don't be daunted, it really is quite easy and the documentation is one of the best I have ever come across. The programmer is always glad to help on the suite's Yahoo group. He is like Tim, he does not sleep. If you do not like that combo, I would suggest you have a look at FLDigi.
    Good luck.
  • Jim Gilliam
    Jim Gilliam Member ✭✭
    edited April 2016
    If it's anything like using Fldigi one needs a CAT interface program to send virtual commands and CAT data between the program and the Flex radio. On Fldigi I am able to key and change frequency within the Fldigi program, and, of course, the DAX is used as a virtual interface for transporting the audio data.
    Jim, K6QE
  • Andrew O'Brien
    Andrew O'Brien Member ✭✭✭
    edited April 2016
    After trying Guy's link, let us know if you need help.  DX Lab works well with a Flex .  You can do a lot if you use your Flex , DDutil, and DXlab.
    Andy K3UK
