Flexradio 5000A is it working with Intel Skylake chipset and windows 7, windows 10??
I tried to built a new fast PC for my Flex-5000a with PSDR 2.7.2. The mainboard was an Asus H70PRO Gaming. With windows 7 and 10 all kind of latency problems.
I build a new system with an ASROCK Z170PRO 4 mainboard. The same problems.
Is there anybody with a SkyLake chipset and a Flex-5000a without a problem?
Matt PA9DX
Welcome!
  • Member ✭✭✭
    edited February 2018
    What I would do?, call Dudly at Flex. Know your chipset on the nic card for your firewire. I'm sure he will get things working well for you....
  • Member ✭✭
    edited April 2016
    Martin, I have a customer who is experiencing issues with the Z170 Southbridge chip, the setup does not work on any setting except 48000Hz/512 bytes setting.
    I sincerely think its a firewire issue with the z170 chipset.
    Does anyone have a firewire card working with a Z170 motherboard?
  • edited March 2016
    The TI XIO2200 used in a lot of FW400 cards no longer works properly on any X99 / Z170 boards and your better off going for a TI based FW800 solution using the XI02213 chipset.
    This card is working here with win10 and skylake.
    Delock PCI Express Card > 2 x external FireWire B + 1 x external FireWire A
    Item No. 89153
  • Member ✭✭
    edited March 2016
    Thanks Martin. Is there documentation online about the incompatibility? The card I was trying to make work was indeed the XIO2200 chipset.
    BTW, this is the chipset used in the recommended firewire adapter from Flex (and the one I use in my computers).
  • edited March 2016
    Dear Neal,
    It's 100% the same problem I had! I think Flexradio shoot update their advice and advice not to use the TI XIO2200A chipset! I tried everything, but a new firewirecard with an other TI chipset made it work. After 4 months of trouble!
  • Member ✭✭
    edited March 2016
    Martin,
    I tried an 800 speed card that had 1 400 speed socket with the same result but I do not think it was the chipset you referenced. I will test with an 2213 card and see how it works.
    Thanks for your feedback. I am sure this will be very common in the next months!
  • edited April 2016
    Neal,
    This is the card I am using. It workes fantastic!
    DeLOCK FireWire PCIe Card, 1xA+2xB Port, Controller(89153, Retail)
