2 Meters on 6700
Burch - K4QXX
I will have my new 6700 sometime next week. I have been using a Flex-5000A for the last several years for both 2 meters and 70cm. How good is the 2 meter receive on the 6700? I do have a mast mounted pre-amp for 2 meters but it will be some time before I can get it on the tower. Just curious how well the 2 meter receive is on the 6700. I am waiting for Downeast Microwave to redesign their 2 meter amp and then I will be able to use the 6700 on transmit.
Burch
Burch
Hi i just testing that right now ...
my test show that direct connection to radio and +30db internal pre-amp have great result
that take me a 31db signal to noise whit -109db rf signal at input ...
whit the 2MLDPA got similar result whit signal to noise ratio ,but in that case radio build in pre-amp setting not really change result ...
whit a WA2ODO pre-amp direct on radio in my urban zone whit pager tower very loud @ 143.866 input overload
and got lot of inter modulation
so all my test point that direct radio connection work best and have great performance even if it on second Nyquist of the ADC
was curious if some one a flex have measure the noise figure and sensitivity of the radio in VHF ?
( find in doc ADL5534 +20 dB gain, 2.5 dB noise figure )
p.s. the L144-28 is easy to transform into a 2MLDPA let me knot if need modification
73 VE2OLM Marc L.0 -
I see that Down East Microwave has posted a notice on their website, indicating they have halted production of their 2MLDPA amplifier due to problems obtaining the existing enclosure, and obsolescence of the 75W hybrid module. It says they are currently doing a full redesign to use a different architecture, in a smaller enclosure that will complement the 6700 in appearance, having 50W maximum output. Check their site for details. 73 KB1MH Mike
Kuhne made one to
http://shop.kuhne-electronic.de/kuhne/en/shop/amateur-radio/power-amplifiers/MKU+PA+2M60W+HY2++VHFMO...
or for "do it your self" lover
http://www.minikits.com.au/electronic-kits/rf-amplifiers/rf-high-power/2m-8W-Amplifier
whit +8dbm it output ~2.5W just good for drive a W6PQL VHF kilowatt VHF deck
i play whit that configuration now ...
http://www.w6pql.com/2m/2mkit.htm
73!0 -
50W output would be perfect for me since my full legal limit 2 meter amp only takes 40-45 watts of drive for 1500 watts output. I spoke via email with downeast and they said they hoped to have some info posted on the new design by the end of April.
- 378 Community Topics
- 116 SmartSDR+
- 923 Genius Products
