CW Skimmer how to change bandwidth
Trevor-EI2GLB
HI All
I am just trying to get to grips with cw skimmer, I have it working with my flex 6500 on slice b as that's where I will be using it most to find where DX is listening,
what I cant seem to do in alter the bandwidth that skimmer skims if that makes scene,
if I scroll the band on skimmer I am only seeing about 18khz how can I change this and can I zoom in/out to see more on the available screen size I have, can I also set the skim edges, so i can only skim a pile up for example,
Trevor
EI2GLB
Trevor
EI2GLB
Why don't you adjust the bandwidth of your 6500?0
Makes no difference in CW Skimmer
Trevor0 -
Hi Trevor,
What you are seeing is normal. Using SDR-Bridge you can run up to 4 skimmers so that may be something that you could try as a workaround.
There is an idea to integrate CW skimmer with SSDR. If that ever happens the spots would be lined up with the panadapter. And the bandwidth of the spots displayed would change as you zoom the panadapter in or out.
https://community.flexradio.com/flexradio/topics/pfskimer_what_is_the_possibility_for_a_smartsdr_dis...
Regards, Al / NN4ZZ
al (at) nn4zz (dot) com
6700 - HW.................... V 1.6.21.77
SSDR / DAX / CAT...... V 1.6.21.159
Win10
Trevor, just set your bandwidth to match your DAX I/Q bandwidth. I use 96k, as this is more than enough. And no, you can't view the whole 96k, although it is decoded.
73, Alex - DH2ID
How do I do that please Alex,
Trevor0 -
Thanks Al
I have a lot of reading/Learning to do
Trevor
EI2GLB0 -
Trevor, it's all in the quickstart and troubleshooting guide by Al NN4ZZ.
url here: http://www.qrv.com/sdrbridge.html
73, Alex - DH2ID
Thanks Alex but that doesn't cover my question and the guide is for v1.0 beta the current v1.5 is very different, I'll try getting help from the author of CW Skimmer, Thanks Trevor EI2GLB0
Hi Trevor,
The quickstart guide is for the latest version of SDR-Bridge and was updated in February.
http://www.qrv.com/download/NN4ZZ%20CwSkimmer%20Bridge%20setup%2018-Feb-2016.pdf
Regards, Al / NN4ZZ
Win10
Thanks Al not sure what I was looking at last night, I still can't see how to alter what I can see in CW Skimmer, also I'm not getting as clean as a decode as in the guide, I have loads of yellow dots on traces bit its not showing call signs0
Trevor,
Decode can be poor depending on the quality of the CW, sometimes very good, other times not so good. Compared to other programs I've seen CWS does a good job.
Yellow dots & no callsigns -- see page 22 in the guide. This might be the issue.
Also check to see if you have "verified calls" set instead of "All Calls."
Regards, Al / NN4ZZ
Win100
- 113 SmartSDR+
- 921 Genius Products
- 124 Antenna Genius
