Congrats to K9CT M/2 team. New Flex 6500/6700 contest station w/alpha version Maestro's...
Clay N9IO
Clay N9IO Member ✭✭✭
ARRL DX Contest, SSB 2016 Mar 5
Writeup on Craig K9CT's 3830 report...
http://www.3830scores.com/showrumor.php?arg=OtajzOgcaavq0
«1
  • Lewis Cheek
    Lewis Cheek Member ✭✭
    edited January 2018
    Take a LOT of rig to warrant replacing the Elecraft K3 stations. Perhaps after alpha team feedback and roll out of Maestro Flex Radio will work on contest enhancements, FRS do you read a question here?
    Lew
    N4CO
  • KY6LA_Howard
    KY6LA_Howard Member ✭✭✭
    edited January 2017
    @Lewis
    You are wrong in your assumptions... the contest configuration envisioned at last year's Dayton Dinner would be a single 6300 with Maestro replacing 2 K3 to run SO2R for about 1/2 the cost of the equivalent K3 configuration and with significantly less cabling and clutter as you no longer need the microham or other associated stuff  and cables to work SO2R
  • KY6LA_Howard
    edited October 2019
     Here is a photo of the K3 Rat's nest clutter at NX6T Contest Station
    https://theta360.com/s/dGW1m3WwyeSK5Bvqgz8ZleYJE
     Photo by NN6X
    This picture is why we are hoping Maestro actually works better than our multiple K3S as a contest machine in SO2R   There are so many crossing cables and ferrites that it has become almost impossible to troubleshoot anything.
  • KY6LA_Howard
    edited January 2017
    Maybe Craig K9CT will publish a picture of his much cleaner layout for his Flex Contest Station.
  • Lewis Cheek
    edited January 2018
    Howard, this was more of a praise than criticism, when a major contest station is planning to replace what has been the contest standard rig for a number of years. While I like my Flex, the software needs some work.
    Lew
    N4CO
  • KY6LA_Howard
    edited January 2017
    Understood... The contest part of the Flex interface is getting very close to being competitive.. and yes there can always be more improvements to everything
  • Lewis Cheek
    edited March 2016
    Hold on a minute, I can think of a number of CONTEST STATIONS that look this way, you're sure it's NX6T? :)
  • KY6LA_Howard
    edited March 2016
    Yes... NN6X took the picture with his 360 degree Theta camera on Saturday and N6KI published it on Sunday after the contest.
    Plus if you look closely you can see my blood and sweat on several connectors when I was trying to untangle and debug the mess...
  • EA4GLI
    EA4GLI Member ✭✭✭
    edited November 2016
    Any RFI?? :)
  • EA4GLI
    EA4GLI Member ✭✭✭
    VOX ;)
  • Craig K9CT
    Craig K9CT Member ✭✭
    edited April 2016
  • W9OY
    W9OY Member ✭✭
    edited March 2016
    This is from Craig's 3830 comments.
    "Not one problem was encountered over the 48 hours. We had the computers, radios and Maestros all on wired ethernet. This was all stable. Not one problem with overload on the same band operation."
    Very Cool
    73  W9OY
  • Charles - K5UA
    Charles - K5UA Member ✭✭
    edited June 2020
    Hi Craig, Can't tell you how many times in this weekend's ARRL DX SSB contest that I called a DX station only to hear him come back to K9CT ! Would have been more discouraged had I not seen photos and video of your amazing antenna farm. Very nice score. Our single transmitter(Flex 6500)/two operator station managed 1412 qsos and about 1,615,000 points. Been contesting with the 6500 for two years now. Glad to see a big-time station adopting the Flex. That should silence the naysayers. See you in the pile-ups. Charles K5UA
  • km9r.mike
    km9r.mike Member ✭✭
    edited March 2016
    Hi Craig,
    It seems that pan adapter display was intentionally limited to maestro and computer displays were dedicated to contest software. Did the maestro provide enough display to satisfy your team's needs ? Were there any gee only ifs as a result of this configuration ?
    I love seeing the pan adapter on a monitor for easy situational awareness and have learned to incorporate the flex knob for maintaining focus on n1mm so I have not thought about the benefit of limiting pan adapter to maestro. Congrats on the fb score.
    PS tnx for k5p
  • Craig K9CT
    edited April 2016
    Comments were quite positive from all team members about the display. They all said it was easier to assess the band very quickly to ascertain a new run frequency. They also said how easy it was to adjust the filters to reduce adjacent signal issues.
    As the Maestro software is evolving, they made some comments about programming that can be tweaked before Maestro is released. All in all they adapted very quickly to how it worked as it is intuitive. The touch screen ability to swipe the band or select stations was a plus that many of us did not consider as we had used a knob prior. This is a plus benefit unlike any other radio. Try that with a P3.
  • km9r.mike
    km9r.mike Member ✭✭
    edited March 2016
    thanks Craig
  • Trevor-EI2GLB
    Trevor-EI2GLB Member
    edited February 2017
    Hi All
    Can anyone tell me on the right monitor the 2nd box up from the bottom on the left side has two frequency readouts, what is that, Is it a N1mm+ window I have never seen it before
    Trevor
    EI2GLB
    https://lh3.googleusercontent.com/-ZCXQebM5zSs/Vt5ILiFujNI/AAAAAAAAyjU/lKfIVBoC3KA/s912-Ic42/2016030...
  • Ken - NM9P
    Ken - NM9P Member ✭✭✭
    edited December 2016
    Yeah! They beat me to the pileup a number of times! Well done.
  • Barry N1EU
    Barry N1EU Member ✭✭
    I'm stumped.
    Just to be clear, it's the window pointed out here:image
  • [Deleted User]
    edited June 2020
    I think it is amazing that some people have 4 Maestro's to play with and some of us loyal customers that have been on the list for almost a year are still waiting for 1 of them . . . GUESS IT IS WHO YOU KNOW !!!
  • Craig K9CT
    edited April 2016
    Hi Barry
    That is the interface to the SteppIR SDA100 controllers. It is PSTRotatorAZ.
    http://www.qsl.net/yo3dmu/index_Page346.htm
     You are seeing only the SteppIR window of that software. It runs off the UDP of N1MM. The GHE runs off the same UDP and selects the antennas and band filters.
    73, Craig K9CT
  • EA4GLI
    EA4GLI Member ✭✭✭
    I was about to say that it looks like SteppIR software.
    This contest station looks awesome!
    Craig, do you guys have a video with a tour of the station?
  • Ken - NM9P
    Since, as I understand it, K9CT was involved in the consultation/development for Maestro, I would expect that his team is heavily testing the alpha release in extreme contest situations in order to perfect it before it is released to the general public. K9CT and 4O3A were presenters at the Flex Banquet at Dayton when the SO2R and Maestro concept were introduced. Unfortunately I had to miss it last year.
  • Gerald-K5SDR
    Gerald-K5SDR FlexRadio Employee ✭✭
    @Steven
    Yes, Craig was directly involved in the design of Maestro and is on the alpha team.  As we have reported in multiple prior communications, we have about 50 units in the field with the alpha group.  We want to make sure the software is more complete before we release to the masses.  We are still filling holes in functionality and incorporating feedback from the alpha team.  I think you all want that too.
  • Steve K9ZW
    Steve K9ZW Member ✭✭✭
    I would like to thank the Alpha team members for their ongoing massive efforts.
    Their work makes for out-of-the-box usable products for the rest of us.
    The quantity of time and quality of intense focus they give Alpha Release products is a process working well.
    Only suggestion I could even think of offering is a communication clarity.  Perhaps by saying these were "Alpha Maestro" would save some angst and later in the ether of looking back at archival forum threads clarify the pre-release aspects of the product?
    Again thank you to the team and 73
    Steve K9ZW
  • Clay N9IO
    Hi Steve,
    I carefully worded the thread indicating K9CT M2 with Alpha Maestros.
    Steve you got it dead right.
    The Alpha team members are the reason the Maestro will be as close to
    perfect as can be when it is finally released and these folks are
    not even on the payroll, just some serious DXers and contesters that recognize the
    potential in Flex 6K radios and want to see it through with the expertise of
    the Flex Radio programming team.
    My pop told me a long time ago that patience is a virtue so I see this
    as well worth the wait for the added enjoyment  it's going to bring.
    History "IS" being made here, great time to be in ham radio.
  • ctate243
    ctate243 Member ✭✭
    edited April 2017
    As a fellow alpha and technical lead at the N6RO CA superstation, I wanted to congratulate Craig, Flex and the K9CT team on this forum for an outstanding contest effort and Flex/Maestro Alpha showcase.  Its not easy doing a major technology conversion at an amateur contest station.  Its expensive in both $$$, time and intellectual clock cycles.  We are just starting to do the first permanant operating position integration at N6RO, and I am deploying the first 6000 with N6NU to the K6LRG remote M/2 hilltop station.
    Flex Signature is rapidly starting to cement its position in contest shacks around the world and I feel like a kid in a candy store to be participating in this.  Its very exciting.
    Clay I am confident your patience will be rewarded.
  • Ernest - W4EG
    Ernest - W4EG Member ✭✭
    edited October 2019
    Yes, I remember that rats nest of cables and the time that it took to get it setup too!
    Nick, N6KI wanted to show the amateur world that a Flex radio would never be able to compete against a K3 or KX3.
    Mind you, My Flex-6700 was received just several weeks before the event and I was running SmartSDR ver.1.0. I bearably knew what the controls did and I had to call KY6LA  to get instructions.
    Now, we see contest stations and their operators are are forming different opinions of the Flex equipment and the cost savings to set them up.
    Flex is becoming the contest radio of the future.
  • W9OY
    W9OY Member ✭✭
    edited March 2016
    If you read Craig's response it does say he is running alpha code on the Maesstro. I for one am very pleased at how well behaved his flex radios are in such an rf rich environment. His system is quite capable of litterally frying a ADC if 2 high gain antennas connected to 1500w got to pointing at each other, yet he reports no problemo. Certainly a testament to his well thought out logistics but also to strength of the radio. 73. W9OY
