program file to configure flex smarts do and flex radios
James Madden
It's so difficult to get 3rd party programs to work. How about having configuration files that will properly configur the 3rd party app and the radio to work?
Do you have an example of those that you are having an issue with?0
There are many YouTube instruction videos available on configuring third party programs. Fldigi is a case in point that explained the need to add a slice configuration file in order to interface with the Flex. It's not easy and takes work but it's worth the effort.0
Ham radio delux and various logging programs aren't working. Dm780 frequently stops showing frequencies, etc..0
I think you are going to find out that every station is unique and much like a thumb print. HRD (free or paid version) does work fine depending on what you are doing with it (Radio Control, Logbook, etc). If you are mostly using DM780, then I would recommend using Minideluxe as your interface to DM780 and not use their radio control.
If it 'stops working' then it must have been working, so that means you do have it correctly configured initially. I would recommend you start with Minideluxe first: https://github.com/krisp/MiniDeluxe/wiki
de va3mw0 -
I have a sneaking suspicion you might have an RF problem, James. If a program works, then stops working frequently, RF is a strong suspect. Even if you don't think so, you can hardly ever go wrong by wrapping toroids around mouse and keyboard cords, or even switching to Bluetooth.0
Not to argue with what is working and what isn't. I use HRD free version and have been using it for about 2 years with my Flex 6700. It's running very well and I haven't had any trouble. I'm currently running SmartSDR v1.6.21. It is extremely stable - at least for me. Even with the earlier versions of DAX and SmartSDR, it worked pretty well. The older versions of DAX occasionally had to be restarted or dinked around with but the new version seems to be pretty stable. I can't remember having any issues that stand out.
I forgot to mention that I just recently started using CWSkimmer. Sometimes when I startup cwskimmer there isn't anything in the cwskimmer waterfall. To remedy this, I have to restart SmartSDR. I'm not sure what is getting out of wack, but the only way I can resolve the issue seems to be to restart SmartSDR.
Is anyone else experiencing this?
Thanks so much.. Jim0
If your using SDR-Bridge, cancel skimmer and re-click the slice check in the skim field in the bridge tab. Make sure the DAX channel is active in DAX and SSDR
73 W9OY0
- 389 Community Topics
- 53 Aurora
- 971 Maestro
- 945 Genius Products
- 307 Shack Infrastructure
