One Global Drop-Down List that Remembers ALL Settings
Phil - N6ERP
While having 3 separate drop-down lists may seem to give a lot of flexibility, for me, I would like to keep it simple & sweet and have just one drop-down list that remembers Everything - ALL SETTINGS. If I Change mics, I can just save another Global setup with all previous settings, but w/ updated settings for the new mic and label the setup accordingly. The key would be having enough Characters in the description to define the setup. Also provide a way to manually sort the items in the order we would see them in the drop-down list (for most commonly used setups first. Etc.) Can keep the existing 3 drop-down lists If felt necessary (Which I think just makes more work, but many will disagree I'm sure), but pls give us just ONE that will remember everything. - Thanks for the consideration, Phil N6ERP
I'm trying to imagine how that would be simple!0
Label your setup and save it.
You can start your Profile labels with 01, 02, 03, etc, that will make those the top ones in the list. Same with Microphone profiles.
When you create a GLOBAL PROFILE it creates a MIC profile as well as a Transmit Profile.1 -
Global profiles can contain nested mic/transmit profiles. That way, you can have a global profile that contains your preferred mic settings on multiple bands without rebuilding the mic settings each time.
Yes, familiar with that. Ty.0
Yes have been doing that (With all 3 lists).. Ty.0
It just seems like managing three lists makes for redundant work, when one list that handles all settings would accomplish the same result.
- 657 The Flea Market
- 438 SmartSDR for Mac
- 203 DAX
- 385 SmartSDR API
- 52 Aurora
- 296 FLEX-8000 Signature Series
- 969 Maestro
- 944 Genius Products
- 467 Remote Operation (SmartLink)
- 809 Peripherals & Station Integration
