I have an Ameritron al-811 amplifier that I'd like to hook up to my 6300.
I have an Ameritron al-811 amplifier that I'd like to hook up to my 6300. If I use a rig buffer like an ARB-704, do I need a special plug and play cable?  Do I need a rig buffer? Etc.  Thanks.
  • Tim - W4TME
    edited May 2020
    No special cables needed.  The ARB-704 is not required, but a keying buffer is recommended as a best practice to protect the 6000 keying interface from voltage transients that may damage it.
  • YV5WZ
    YV5WZ Member ✭✭
    edited December 2019
    I have ameritron 811.....I used to use a Heil FS-2 Foot switch.....and it worked good....thats alll you need...however I thought my Flex needs something more advanced ....and I got an Elecraft KPA500.....Now its seems I have a Flex 6300 with 500 watts
    George
    YV5WZ
  • Bob  KN4HH
    Bob KN4HH Member ✭✭✭
    edited May 2017
    If you like the Rube Goldberg (if you remember that, I know how old you are) approach, I used a Radio Shack 5vdc relay and borrowed 5vdc from the accessory connector on the back of the Flex.  I keyed the relay with the TX1 contacts and key my amplifier with the SPST contacts of the relay.
  • ctate243
    ctate243 Member ✭✭
    edited April 2017
    I use an ARB-704 and it works fine
  • PB Shell - k7shl
    edited June 2016
    George,
    What kind of cable did you use with the Heil FS-2?  Do I need a microphone cable assembly (like the CC-1Y) or ??
    Thanks.
    -Phil, K7SHL
  • YV5WZ
    YV5WZ Member ✭✭
    edited December 2016
    I don't Recall at this moment...but I will check tonight and letting you to know
  • James - K4JK
    James - K4JK Member ✭✭
    edited April 2016
    Remember to use TX delay when using an amp with a slow relay like an 811.
  • Dave S
    Dave S Member ✭✭
    edited May 2020
    Hello, Trying to interface my 6400 to and old Ameritron 811... can you recommend an alternate keying buffer?
  • Bill -VA3WTB
    Bill -VA3WTB Member ✭✭✭
    edited May 2020
    You can't use the Ameritron one?
