cw skimmer setupwith SmartSDR v 1.6.21
Roy Finch
Roy Finch Member
edited March 2017 in SmartSDR for Windows
Hi all,
are there any good articles on how to setup the latest cw skimmer on the latest version of SmartSDR v 1.6.21?
  • DH2ID
    DH2ID Member ✭✭✭
    edited March 2017
    It's all here : http://www.qrv.com/sdrbridge.html and in the excellent tutorials
    under "quickstart".
    Version 1.6.21 of SmartSDR didn't change much, but the new version 1.5.0 of SDRBridge did! The connection is much more stable now.
    I run CW Skimmer this way:
    1) Slice set to CW, 400Hz bandwidth, DAX set to I/Q 96k
    2) CW Keyer by ZLP electronics with extra com port plugged into Flex6k5
    3) HRD DigitalMaster with winkeyer support connects to that com port
    4) SDRBridge 1.5.0
    5) CW Skimmer
    6) WK profiles in SmartSDR for the main bands, switching works from DM
    7) Iambic paddles connected to CW Keyer, can take over at once this way
    Toggle frequencies 1-2 times between CW Skimmer and SSDR -> runs!
    Alex - DH2ID
  • Roy Finch
    Roy Finch Member
    edited March 2016
    Tank you Alex,
    All seems to be in and working just need to tweak it a bit, but again many thanks.
    Roy
