N4PY Software now supports the Behringer CMD Micro DJ Controller
I now have full support in Pegasus Plus Beta for the Behringer CMD Micro   DJ Controller.  This device has 10 knobs and 20 buttons offering   ultimate knob control for your radio.    All the knobs and buttons are fully user definable.  Right now this is   available in Beta form for Pegasus Plus on my test page.  It is in   version 4.23E or later.    These devices are a great bargain and can be found for around $60.
  • James Del Principe
    James Del Principe Member ✭✭✭
    edited March 2016
    Carl, does this work with SSDR? at what release?   I assume that one still uses their own computer for video. How bad is latency in control? How does one get the SW to interface?   Any further information?     Many Thanks, Jim      KD1I
  • Carl Moreschi
    Carl Moreschi Member
    edited March 2016
    Yes, this runs in conjunction with SmartSDR.  My N4PY Pegasus Plus connects to the Flex 6000 radios.  There's just one setting you turn on in Pegasus Plus to hook up the DJ controller.  And Pegasus Plus connects to the Flex 6000 radios radios by simply selecting that radio type.
    All buttons on the DJ controller can be configured by you to over 60 different functions.
    You can download and install Pegasus Plus from my webpage.  This function is only on my Test page in Beta so once on my home page, select the test page from my "More" menu.  Then download and install n4py423E.exe.  It will run for 10 days without a password.
    Carl N4PY
